    1,189
  1. The parts fiche shows a sealing washer under the "reduction" adapter to the sump. I was hoping the leak was there, but looks to be the pipe fitting itself. I have "reseated" it and will hope for the best. Otherwise, time for another $100 gift for the Old Girl. (the ever quixotic docc . . . )
  2. Oh, yeah, I’m sure I tightened it more than that. Is there a valve in there or will the sump drain if I take the line loose?
  3. So, the fitting is not NPT, for certain. I was hoping to wait for the next oil change to remove the line. As always, thanks to you folks for the insight and education!
  4. AN is just a standard for fittings. So, am I right thinking it is some kind of a flared line in there? Mates up to the nipple czakky mentioned?
  5. Not sure what an AN fitting is. But, you’re saying once they start leaking, it’s time for a new line?
  6. For long while, I thought the leak was from the small rubber open hose (my combined fuel tank vent and tank over flow). In this image, I have cleaned it all up, applied foot powder and ridden 25 miles/ 40 km. The leaks are barely visible at the joint and mouth of what I believe is a flare fitting (?)
  7. I was hoping it would be the sealing (crush) washer, but looks to be weeping from the "flange fitting", itself (?) All this nipple talk gets me worked up, so I "re-seated" the hose fitting (loosened and tightened and repeated until I cranked it down right-well). If there is a nipple in there, it should be impressed by now!
  8. I have had the funkiest intermittent leak of something that looks like "PB Blaster" that I thought was coming from the tank vent/overflow. Turns out it is coming from the crankcase vent return line. It is tight. And re-tight. (edit/July 2019: my leak is from the vent/overflow, but read on, as there is good info on the return line and changes to those fittings over the V11 production run . . .) Is there any hope when these start to weep?
  9. Turns out this mudguard has more "shop wear" than I recalled. Anyone out there (say, in sunny California ) with a pristine rear mudguard they took off the first day they brought their V11 home? Twin AH is still hopeful!
  10. Welcome, Tennmoto! Can't wait to see that red Sport at the next South'n Spine Raid (First weekend after Labor Day, Tellico Plains, Tennessee)!
  11. I had to test my bad TPS by unhooking it and checking the resistance in Ohms while slowly opening and closing. I found a spot that "jumped" where the TPS had gone bad. Canonman, have you performed the full "Decent Tune-up" that czakky posted in Post#2?
  12. I like the idea of a switch to connect and disconnect. Would love to see a picture of the circuit breaker you’ve installed. Check out pages 4 and 5 in this thread showing how I installed this style of circuit breaker:
  13. Good advice to service the connections under the top rubber cap. I see this entry in the Wheels Off Maintenance Checklist: >Remove the top and bottom rubber caps from the rear brake master cylinder and inspect, clean, and lubricate. Use only silicone based grease around brake parts (under the master cylinder, inside the rubber cap). Make sure there is good electrical connection to the switch at the top and avoid the silicone based lubes (dielectric) on electrics - simple petroleum jelly (Vaseline®, or better: Caig DeOxit Gold®) will keep the moisture out. Grease does not conduct electricity - it's just to keep the moisture out. http://www.v11lemans...=18158&p=192643
  14. have you documented this project Roy, here or elsewhere? Kiwi_Roy's thread, Installing Speedhut Gauges in "How to . . ." The first post contains Kiwi_Roy's typical level of expertise, excellent detail, and documentation. The rest of that thread (15 pages!) documents several other approaches to Speedhut installation. Some of the images have been lost, but the thread is phenomenal.
  15. I would be nervous pulling that fuse in and out since the holders are already known to be weak. Easy for me with the switchable circuit breaker installed. Yet, aren't those the same diodes that can "go bad" in the SCR regulators?
  16. @bbolesaz, True, that. I've learned to place online Guzzi parts orders (with whomever), and call a few days later on availability confirmation. With MotoInternational shuttered, I'm bouncing between Harper, MGCycle, and AF1 Racing. AF1 in Austin, Texas, probably has the best website interface, but no knowledge of these "old guys' Guzzis . . . "
  17. Nope. The Speedhut only bump their needles slightly on initial activation (nothing spectacular like the late model Guzzi's full sweep and full illumination). This is the recorded max speed displayed digitally while the needle sweeps up to show the retained measure.
  18. Will do. Let me know if the one in MA/USA is still available. It is priced right and looks good.
  19. This cleaned up decently. I wouldn't call it "as new." Maybe "as new with fifteen years of shop wear." It is the best of my three. I can pm you pics, if you like. Is this one still available in Massachusetts, USA? http://www.2040-parts.com/moto-guzzi-v11-sport-rear-fender-oem-gu01437030-i1367027/ Harpermoto lists them $52.50US. Not sure that means they are actually available?
  20. This one should fit. I'll get it cleaned up this evening and see what kind of shape it's in. Came off a V11 Sport in California in 2003, so should be about as close to "like new" to anything we'll find.
  21. Let me dig around and see if anything I have is any place close to "like new" . . .
  22. I love my JoeK headguards. His brake lever is just too awkward for me to consider. The German piece (through MGCycle in the USA) shows some elegance, so I'll get one when (if) the silver comes available again. Anyone know who is actually building the German part?
  23. The inner "hugger" or the hanging outer that mounts the license plate?
  24. Here's to the pure entertainment quality of Speedhut gauges!
  25. footgoose made an interesting observation that the early Sport (1999-2001) rear brake foot lever is about 5/8" shorter than the later V11s. This one came off a Rosso Corsa and looks to be 15mm longer than the original on my 2000 Sport. The measure from the pivot to the master cylinder plunger is the same. Looks like a little bend upward, as well: A couple years back, Scud pointed out that later V11 gear shift levers differ. At the time, I thought that was only about the mounting end because of the different subframe on "LongFrame" V11, but it seems likely that later foot shift levers are slightly longer to match the brake lever. MGCycle and Joe Kenny are both offering replacement rear brake levers. The MGCycle product is made in Germany, black or silver, to the longer, late model dimension. Not sure the length of the Joe Kenny piece. http://www.mgcycle.com/index.php?main_page=product_info&cPath=50&products_id=2795 https://www.ebay.com/itm/Moto-Guzzi-V11-Sport-Rear-Brake-Pedal/352493164895?hash=item52123ad95f:g:HZMAAOSwCJxaFgng:rk:2:pf:0
