Craig Posted September 11, 2016 Share Posted September 11, 2016 I just went and looked at the detent roller again after running it through the gears several times. It is getting punched by the ridges on the detent ring. It is too soft for the application. I wonder if I can find a hardened steel bearing that would fit. Link to comment Share on other sites More sharing options...
Scud Posted September 13, 2016 Share Posted September 13, 2016 I just ordered a roller from Harpers. They didn't have it in stock; they show it as available, but "low inventory" - and not sure how long it will take to get one. Craig, if you do find a compatible part, please advise. Link to comment Share on other sites More sharing options...
Craig Posted September 18, 2016 Share Posted September 18, 2016 I finally installed the roller bearing I found at McMaster Carr. It is a 8mmx16mmx5mm high precision ball bearing. They go for $6.13 each. They are dimensionally identical to the solid roller installed by Guzzi. I doubt they will make a noticable difference in shift feel, but they can't hurt either. 1 Link to comment Share on other sites More sharing options...
JesterGrin_1 Posted September 27, 2016 Share Posted September 27, 2016 I finally installed the roller bearing I found at McMaster Carr. It is a 8mmx16mmx5mm high precision ball bearing. They go for $6.13 each. They are dimensionally identical to the solid roller installed by Guzzi. I doubt they will make a noticable difference in shift feel, but they can't hurt either. Any updates on the Bearing? This may prove to be good information for those that may need it and or those that just simply wish to improve what they have. Link to comment Share on other sites More sharing options...
Craig Posted September 27, 2016 Share Posted September 27, 2016 The bearing I listed fits perfectly. It will be some time before I can road test it. 1 Link to comment Share on other sites More sharing options...
Scud Posted October 4, 2016 Share Posted October 4, 2016 OEM Part Name: Roller - for gearshift selector lever Moto Guzzi Part Number: 04234700 Replacement Part Brand: Dynaroll Part number 688HZZ A5 Differences from OEM (if any): This is a bearing, the OEM part is a solid piece. Other Comments: Craig found these and sent one to me. I just installed and it works. Thanks. Bearing dimensions: 8mm x 16mm x 5mm IMG_5369.jpg IMG_5370.jpg I would think that the replacement True Roller bearing would be smoother and probably less prone to wear? I think the shift action was smoother with the bearing. But I also installed a new spring on that arm at the same time, which could have helped. Oh - and I have road-tested it, but just a short distance. 1 Link to comment Share on other sites More sharing options...
czakky Posted March 21, 2017 Share Posted March 21, 2017 Went for a quick and...chilly ride yesterday. My shifting sucks! After re-reading this thread I'm submitting to Phils advice. I'm taking the plunge and attempting to do this procedure.... as best I can. Link to comment Share on other sites More sharing options...
Scud Posted March 22, 2017 Share Posted March 22, 2017 Check your external shift linkage first. Is the foot lever free or binding? The lever pivot bolt can be adjusted for tightness - then locked in place by a secondary nut. Is the linkage nice and tight? A loose bolt on either end of the linkage will ruin your shifting. Is it rubbing on anything or hitting anything? The nut on the forward part of the linkage can hit the starter or the transmission case if it's not on right. After all that... off with the pre-selector. I was pretty intimidated by it at first, but it can be done. 1 Link to comment Share on other sites More sharing options...
czakky Posted March 22, 2017 Share Posted March 22, 2017 Is the sheet metal stop plate under the cog, oriented correctly? Should be in neutral. Link to comment Share on other sites More sharing options...
czakky Posted March 22, 2017 Share Posted March 22, 2017 Also is my pawl spring sitting right? This is a fresh one. It just seems like on the selector side it is barely seated. Link to comment Share on other sites More sharing options...
Scud Posted March 22, 2017 Share Posted March 22, 2017 Pawl spring looks right to me. But you can push the coil up and down with a screwdriver to see if you can make it sit better. It will probably just relax into its own best spot after a few shifts anyway. The metal plate under the upper cog only goes in one way. It has a tab that fits a slot on the underside of the cog. Link to comment Share on other sites More sharing options...
czakky Posted March 22, 2017 Share Posted March 22, 2017 Thanks Scud, that's what I thought. Just needed a vote of confidence! Link to comment Share on other sites More sharing options...
Scud Posted March 22, 2017 Share Posted March 22, 2017 It's normal to have a little performance anxiety on your first time - not being sure how everything is supposed to fit. Now you'll never forget this transmission. Set innuendo on maximum... 2 Link to comment Share on other sites More sharing options...
Scud Posted March 23, 2017 Share Posted March 23, 2017 Pardon my prior playfulness. Here's some actual advice: I needed to re-install a bushing on my pre-selector (since I overlooked it a few days ago). So I took mine off just now. Having done it a few times recently, here are some lessons learned. You want as clear and straight an approach as possible so you don't get sealant everywhere. (How did I learn that???) It's a good idea to dry-fit it first (without sealant) so you have a feel for it and don't get sealant everywhere (again, how do I know?) Loosen the lower nut on the oil return line and wedge the line as far away from the transmission as possible. If your fuel line is in the way (top right) you can wedge a screwdriver in there to keep it above the transmission case. And you probably already figured out that you need to grind down a hex wrench to get at some of the lower bolts. This would not be a problem on the red-frame bikes, because there is no frame rail connecting the engine block to the lower transmission bolt (that goes through the porkchops. 2 Link to comment Share on other sites More sharing options...
ani Posted March 23, 2017 Share Posted March 23, 2017 Number 2 is even more important if the bloody pawl spring decided to die while in some gear. Which it usually does. I then typically forget which gear the mechanism should be in when I'm about to refit. It usually takes some searing, thinking, fiddling with the play in the forks, and switching gears in the mechanism before everything fits snugly. After a quick check that you can switch gears and can easily find neutral (Two screws to hold the plate in place while testing) I remove it again before refitting with sealant. 1 Link to comment Share on other sites More sharing options...
