docc Posted April 28, 2023 Author Share Posted April 28, 2023 Correct, the TPS is set/ "baselined" with a multimeter, not with guzzidiag. 1 Link to comment Share on other sites More sharing options...
Martijn851 Posted June 11, 2023 Share Posted June 11, 2023 Guzzidiag doesn't connect to the V11, so what am I doing wrong? I've got the right cables, connected to the battery, blue light goes on when plugged to the laptop and turned the key. Link to comment Share on other sites More sharing options...
Tomchri Posted June 11, 2023 Share Posted June 11, 2023 Rumors mention, voltage is important. And you chosed the correct bike ? Cheers Tom. Link to comment Share on other sites More sharing options...
Martijn851 Posted June 11, 2023 Share Posted June 11, 2023 Full battery, also tried an external one and yes, correct bike. Link to comment Share on other sites More sharing options...
docc Posted June 11, 2023 Author Share Posted June 11, 2023 Downloaded the correct FTDI driver? 1 1 Link to comment Share on other sites More sharing options...
Martijn851 Posted June 11, 2023 Share Posted June 11, 2023 16 minutes ago, docc said: Downloaded the correct FTDI driver? I checked that on the Lonelec site and manually installed them, just back from the garage and feeling all nerdy that I fixed it myself CO trim is -128, will try to change that tomorrow. 3 Link to comment Share on other sites More sharing options...
docc Posted June 11, 2023 Author Share Posted June 11, 2023 44 minutes ago, Martijn851 said: I checked that on the Lonelec site and manually installed them, just back from the garage and feeling all nerdy that I fixed it myself CO trim is -128, will try to change that tomorrow. A new record for negative CO ! 1 Link to comment Share on other sites More sharing options...
audiomick Posted June 11, 2023 Share Posted June 11, 2023 2 hours ago, Martijn851 said: feeling all nerdy that I fixed it myself Well done, that man. Link to comment Share on other sites More sharing options...
Martijn851 Posted June 12, 2023 Share Posted June 12, 2023 Well, I can see the data, but the bike won't start wenn connected and asked for to set the co trim. Link to comment Share on other sites More sharing options...
docc Posted June 12, 2023 Author Share Posted June 12, 2023 There is another way to set the CO directly in the EEPROM that @Meinolf has showed us. I will look for the post. Otherwise, why would your bike not start? Does it make a click or whir at all? Link to comment Share on other sites More sharing options...
Martijn851 Posted June 12, 2023 Share Posted June 12, 2023 When connected to the laptop is does nothing, no fuelpump, not cranking. Once disconnected it fires right up. Link to comment Share on other sites More sharing options...
docc Posted June 12, 2023 Author Share Posted June 12, 2023 1 hour ago, Martijn851 said: When connected to the laptop is does nothing, no fuelpump, not cranking. Once disconnected it fires right up. Hmmm, that's an odd one. Never heard that before. For sure the Run/"kill" Switch is on and the clutch lever being pulled in? Link to comment Share on other sites More sharing options...
Martijn851 Posted June 12, 2023 Share Posted June 12, 2023 Yes, I'll try the other method next week. 1 Link to comment Share on other sites More sharing options...
Martijn851 Posted June 14, 2023 Share Posted June 14, 2023 Tried the other program, doesn't read the ecu, not via port 3 or 4. I'm stuck, not the computer nerd I thought I was, should have known that Link to comment Share on other sites More sharing options...
PJPR01 Posted June 14, 2023 Share Posted June 14, 2023 Make sure the ignition is on AND the fuel pump switch is on, or Guzzidiag will not connect. Link to comment Share on other sites More sharing options...
