swooshdave Posted April 21, 2017 Share Posted April 21, 2017 I still need to figure out how to change the front tire. I can borrow one of the side lifts which should get it off the ground just enough. you could do as Chuck mentioned and back the bike in. Nice Norton btw. I owned a 75 for several years. Sweet sound. Garage art. Yeah but I need to still jack the bike slightly. I have a worthless scissor jack that I don't trust. Hmm, maybe the stand for the Bultaco might work. The Norton is definitely a piece of garage art now after it threw a rod through the bottom of the crankcase. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Scud Posted April 21, 2017 Share Posted April 21, 2017 This platform jack has served me really well. Once you stabilize the rear (a standard swingarm stand will work) you can put the platform jack under the engine to lift the front wheel. ...or you could leave the wheel on and use the platform jack to take out the engine... Link to comment Share on other sites More sharing options...
Chuck Posted April 21, 2017 Share Posted April 21, 2017 Just a heads up. After unpacking my $299 HF lift, I too, wondered why I hadn't done it years ago. But. A careful inspection revealed a missing nut on one of the scissor arms. If that bolt had eventually worked it's way out it would have certainly ruined my day. I removed and thread locked all nuts, topped up the hydraulic cylinder, and have used it for years, now. Link to comment Share on other sites More sharing options...
docc Posted April 21, 2017 Share Posted April 21, 2017 Good points. After, years of use, it's probably a good time to do a thorough inspection on mine. Is there a recommended procedure to fill the cylinder? Link to comment Share on other sites More sharing options...
swooshdave Posted April 21, 2017 Share Posted April 21, 2017 Good points. After, years of use, it's probably a good time to do a thorough inspection on mine. Is there a recommended procedure to fill the cylinder? Hydraulic oil + hole. Insert A into B. The cylinders are typically low from the factory. Regardless, use the safety bar when lifted. Link to comment Share on other sites More sharing options...
swooshdave Posted April 21, 2017 Share Posted April 21, 2017 This platform jack has served me really well. Once you stabilize the rear (a standard swingarm stand will work) you can put the platform jack under the engine to lift the front wheel. ...or you could leave the wheel on and use the platform jack to take out the engine... Any idea where you got the platform jack from? I've been looking for something like that. Link to comment Share on other sites More sharing options...
BigBlock Posted April 21, 2017 Share Posted April 21, 2017 I bought one like this, there might be some out there that are cheaper or better but this one seems to do the trick. https://www.amazon.com/Smartxchoices-Motorcycle-Center-Scissor-Hoist/dp/B01M9C4F7K/ref=sr_1_30?ie=UTF8&qid=1492797083&sr=8-30&keywords=motorcycle+jack+lift 1 Link to comment Share on other sites More sharing options...
swooshdave Posted April 21, 2017 Share Posted April 21, 2017 On my list now! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
bbolesaz Posted April 25, 2017 Share Posted April 25, 2017 Very similar is a transmission jack. Check Harbor Freight. Link to comment Share on other sites More sharing options...
swooshdave Posted April 25, 2017 Share Posted April 25, 2017 Very similar is a transmission jack. Check Harbor Freight. I have a transmission jack but it's not rated high enough to lift a bike. I think it's only good for 250lbs. Link to comment Share on other sites More sharing options...
docc Posted April 25, 2017 Share Posted April 25, 2017 The Amazon scissors jack is "rated" for 1,000 pounds. And matches my lift and RedFrame! Link to comment Share on other sites More sharing options...
bbolesaz Posted April 25, 2017 Share Posted April 25, 2017 I guess I must have a "heavy duty" tranny jack. It has wheels and I use it to drop the engine from a GL and roll it out the side. I do like that the amazon piece is much shorter retracted. My tranny jack needs about 6" of clearance. Link to comment Share on other sites More sharing options...
footgoose Posted April 25, 2017 Share Posted April 25, 2017 I guess I must have a "heavy duty" tranny jack. It has wheels and I use it to drop the engine from a GL and roll it out the side. I do like that the amazon piece is much shorter retracted. My tranny jack needs about 6" of clearance. as long as we're on the "jack" topic, which one is yours? I like the idea of wheels on it. Link to comment Share on other sites More sharing options...
swooshdave Posted April 25, 2017 Share Posted April 25, 2017 This is the one I have: http://www.harborfreight.com/450-lb-low-lift-transmission-jack-61232.html Rated at 450 lbs which is probably just a little low for a V11. They do have a higher rated one at 800lbs. http://www.harborfreight.com/800-lb-low-lift-transmission-jack-69685.html Link to comment Share on other sites More sharing options...
bbolesaz Posted April 25, 2017 Share Posted April 25, 2017 Yep, I got the exact same 450lb one. Has removed several GL and Airhead engines with no issues. I have a sheet of plywood bolted to the top to better stabilize the motor on the platform. Link to comment Share on other sites More sharing options...
