thumper Posted June 3, 2019 Share Posted June 3, 2019 Just came back from a 80 mile run and checked my voltage at the battery. At idle 13.2 volts at 4/5 thousand RPM 14.9 is that to high or am I OK Thanks for the help Link to comment Share on other sites More sharing options...
swooshdave Posted June 3, 2019 Share Posted June 3, 2019 I didn't freak out until I was at 17v+ while riding. 1 Link to comment Share on other sites More sharing options...
Chuck Posted June 3, 2019 Share Posted June 3, 2019 3 hours ago, thumper said: Just came back from a 80 mile run and checked my voltage at the battery. At idle 13.2 volts at 4/5 thousand RPM 14.9 is that to high or am I OK Thanks for the help As long as you don't go over 14.9, you're golden. 1 Link to comment Share on other sites More sharing options...
thumper Posted June 3, 2019 Author Share Posted June 3, 2019 Thanks!!! Link to comment Share on other sites More sharing options...
docc Posted June 4, 2019 Share Posted June 4, 2019 Yep, Odyssey says not to exceed 15.0v. But I wonder what the condition of the battery was before the ride? (As in under, or well under the 12.65v Odyssey charging threshold) . . . Also, you have added the regulator case-to-engine ground strap and have had a look at the condition of your green 30 amp fuse (for melting or signs of heat damage)? Link to comment Share on other sites More sharing options...
fubar guzzi Posted June 9, 2019 Share Posted June 9, 2019 I own a 98 EV behind the side cover operator side is a THING,it looks like regulator except 2/3 times larger,has about ten wires coming from it. on it is marked,Magneti Marelli aei 450 B,can someone help me identify what this thing is? I will feel stupid later ,thanks!!!! Link to comment Share on other sites More sharing options...
footgoose Posted June 9, 2019 Share Posted June 9, 2019 that's the ECU Link to comment Share on other sites More sharing options...
fubar guzzi Posted June 9, 2019 Share Posted June 9, 2019 Thank you Mr. Goose for your speedy reply! So, if thats the ECU what is the big square box(8")next to the battery,I thought that was the ECU!!! Please correct me,thank you. Link to comment Share on other sites More sharing options...
sp838 Posted June 9, 2019 Share Posted June 9, 2019 When you say "98 EV" are you talking about a California? Those have two CDI boxes. One mounted on the side, one by the battery. You can see them here: http://www.harpermoto.com/parts-lookup/1990-1999-moto-guzzis/california-ev-v11-ev-usa-1100-1997-2001.html The V11 Lemans don't use these. Link to comment Share on other sites More sharing options...
fubar guzzi Posted June 9, 2019 Share Posted June 9, 2019 I find this most confusing ---- but I guess I understand?--- the cdi is mounted to the ecu witch is next to the battery. Why didnt they abbreviate battery also??? Because 1cdi isnt enough th ey installed #2 cdi behind the side plate,so you say,whats the problem? nothing here,I'm gonna have to get me a larger bottle of Bn(bourbon) too cope!!!! Thanks for your imput 3 Link to comment Share on other sites More sharing options...
sp838 Posted June 9, 2019 Share Posted June 9, 2019 1 hour ago, fubar guzzi said: I'm gonna have to get me a larger bottle of Bn(bourbon) too cope!!!! lol ok... keep the shiny side up, bruv. Link to comment Share on other sites More sharing options...
luhbo Posted June 10, 2019 Share Posted June 10, 2019 Written on my Odyssey ( as on probably every single one sold the last 20+ years) is 13,8V charging voltage for floating use. If you want to be nice to your battery you better keep the voltage in this range. If your 14.9 are real, then something's wrong with your charging circuit. Only for those who drained theirs (in spec) it's below 14.8V, no inrush current limit. Exide claims at least 40A/14.8V in case the battery shall fully recover from a deep discharge. If you take this serious you better don't drain it that deep (10 and less). 40x15=600W is a lot, maybe a charger for lorry batteries could come somewhat close. 1 Link to comment Share on other sites More sharing options...
