Lucky Phil Posted January 25, 2021 Report Share Posted January 25, 2021 I've experienced casting porosity quite a few times over the years with Italian motorcycles so why would the V11/V10 be any different. I thought I'd do a piece on dealing with it in the case of the Daytona engine, specifically the cylinder head. It's of course of no real import to anyone here V11 wise but may be of general interest. My original V11 engine had an issue with the oil drain back gallery in the l/h head apparently which the original owner had rectified with a sleeve. I've not had the opportunity to look at it but it has never leaked in the 10 years I've owned the bike, so I'll call it fixed. The issue with the Daytona engine arose a few months after I got it running with an annoying accumulation of a small amount of oil on one of the r/h cylinder fins. Originally I put it down to a leaky rocker cover gasket but a careful evaluation found it to be from one of the rocker cover attach screw blind holes. Four of the cover retaining screws are on the "wet" side of the cover o-ring and are blind holes to the external part of the head. Several of these holes had been over drilled at the factory by a very small amount and broken through to the head exterior. Oil was seeping down the thread holes and working its way to the outside and eventually to the edge of the cooling fins. Great, simple fix. Either seal the screws on fitment of the rocker cover, which is a bit of a pain or somehow seal the bottom of the holes. I took the latter path and screwed a 6X4 grub screw down to the bottom of the holes sealed with Loctite 242. This still left me with 12mm of thread engagement which was plenty. Here's a totally inadequate image of the screw hole with the grub screw in the bottom. Unfortunately the leaks persisted. I suspected it may have been from the spark plug drain gallery vertical wall. The vertical walls of this area of the head form an internal pair of drain "wells" with the head drain galleries at the bottom of these rectangular wells. Measuring a spare head I calculated the wall thickness here to be around 3mm which is pretty thin for a sand casting. I also recalled a brief thought flash through my mind when I was painting the heads that I'd better get paint up in there or I might end up with an oil seep issue. Funny the fleeting thoughts that come back to you in hindsight. I've long suspected that one of the primary reasons for the Italians painting engines going back 35 years of so was to preclude these porosity issues. Here you can see in this damaged spare head the drain wells and the spark plug drain gallery exit between the fins. One well has a red sealing coat over the area that forms the roof and vertical wall of half the plug drain gallery and the other roof section and vertical wall section is unsealed. I wanted to test the sealer in the oven to makes sure it would stand the local heat in the head. I painted on some dye check developer to these vertical walls inside the plug drain gallery and sure enough the tell-tale signs of porosity seeping. First image the r/h head and the second the l/h. The dark round patches in the white developer are the tells. So the challenge is how to fix this without pulling the heads if possible. Pulling the heads is a pain. Apart from the actual work involved you then need to go through the retorque process and reset the valve clearances etc. painful. Part of what I did in my professional aviation career was to come up with insitu technical solutions to to keep aircraft out of the hangar flying an earning a dollar so I put that hat on and had a muse. The typical way to address porosity issues is to clean the component, heat it up which will usually bring any trapped oil out of the casting and then drop the whole thing in a warm bath of loctite 290 wicking grade and let it soak for a few hours and wash it down and the porosity is sealed. Not possible here of course without pulling and disassembling the heads. There are commercial variations on this process that immerse the component in a vacuum chamber and then a pressure chamber of 290 or variations on that material but once again not insitu. What I eventually came up with was a vacuum system using a brake bleeding pump and home made rubber seal. I sealed off the spark plug end of the plug drain gallery with aluminium tape and connected my homemade seal to the vacuum pump at the outer end to create a 27 inch vacuum in the plug drain gallery. The outer rubber seal was made from an old piece of rubber thong sole. This would hold a vacuum quite well with a few pumps every 3 or 4 minutes. An image of the aluminium tape used to seal the plug drain gallery at the plug hole end I then devised a rubber plug to seal the drain hole in the bottom of the head drain wells. A little tricky as with the head rocker gear support installed the hole isn't visible without a mirror. Here's the plug. Here's the plug installed on the head on the engine with the drain well filled with 290. Some of the images are from "proof of concept" experiments with my spare damaged head on the bench. Painting on the internal sealer insitu was a fiddly job with the rocker arm supports in the way but with small brushes bent to various shapes quite doable. So the process now was to fill the plugged drain well and fill them with solvent and pull a vacuum in the plug drain gallery to draw the solvent through the porosity and clean out residual oil. Then dry out the drain well and repeat the process with the loctite to seal the porosity. I inserted a small piece of paper towel inside the plug drain cavity on both occasions with the solvent and the loctite to get an indication if my process was sound. If you look carefully you can see a light green tinge to the paper, so the solvent and loctite were migrating through the porosity. So repeat for the other head area and the jobs almost done. I wanted a little "belt and braces" assurance so in addition to the loctite sealing I also coated the well areas with Glyptal internal engine sealer as well. That's the reddish coating. So I can claim a complete success I'm happy to say. Nice and oil tight. Next time I'll listen to my small internal voice a bit more closely and do the due diligence on those areas I know intuitively could be an issue. Ciao 1 6 Quote Link to comment Share on other sites More sharing options...
pete roper Posted January 25, 2021 Report Share Posted January 25, 2021 I've had a few porous heads on 8V's, the castings are quite thin and the cooling drilling's complicate things. I've had quite good success using Loctite 'Super Wick-in', can't remember the number. Sometimes a smear of epoxy over the top works wonders. 2 Quote Link to comment Share on other sites More sharing options...
Lucky Phil Posted January 25, 2021 Author Report Share Posted January 25, 2021 17 minutes ago, pete roper said: I've had a few porous heads on 8V's, the castings are quite thin and the cooling drilling's complicate things. I've had quite good success using Loctite 'Super Wick-in', can't remember the number. Sometimes a smear of epoxy over the top works wonders. Yes Pete "super wick-in" is the 290 green stuff. Low viscosity. And yes Araldite is another fix. Many round case bevel drive Ducati's back in the early 70's had Araldite in the cases from the factory. When I put Desmoquatro engines together with new cases I used to go to the importers and they would bring out their whole stock of crankcases and I'd go through them and chose the one with the least porosity. Not, no porosity but the least! Ciao 2 Quote Link to comment Share on other sites More sharing options...
68C Posted January 27, 2021 Report Share Posted January 27, 2021 Resin impregnating would work best with a new set of cases that had never seen oil. MV did it in their early 750s, do not know how they did it, I imagined some kind of tank with the casing completely submerged and put under pressure. Must have been fun determining the time to leave it in the tank, to short and not fully impregnated, too long and nicely encased in a solid block of resin. These folk seem to have it covered, interesting read. https://www.midlanddeburrandfinish.co.uk/casting-impregnation?gclid=CjwKCAiAu8SABhAxEiwAsodSZIgrKkXwzzYCJq7A8IJACW-TTPC0_4hlMRPaw1ke-C4BFyDGMyUWTxoCKt0QAvD_BwE 2 Quote Link to comment Share on other sites More sharing options...
Pressureangle Posted January 27, 2021 Report Share Posted January 27, 2021 Old Harley-Davidsons, particularly the sand-cast engines nearly always had some porosity. As you've done here, Glyptol was the most common answer, after a solvent bath and oven baking. V8 Automotive guys use it too. Interestingly, Jack Roush Engineering used (uses?) copper plating on the entire block, because it can in no way peel off and compromise integrity. 2 Quote Link to comment Share on other sites More sharing options...
Lucky Phil Posted January 27, 2021 Author Report Share Posted January 27, 2021 7 hours ago, 68C said: Resin impregnating would work best with a new set of cases that had never seen oil. MV did it in their early 750s, do not know how they did it, I imagined some kind of tank with the casing completely submerged and put under pressure. Must have been fun determining the time to leave it in the tank, to short and not fully impregnated, too long and nicely encased in a solid block of resin. These folk seem to have it covered, interesting read. https://www.midlanddeburrandfinish.co.uk/casting-impregnation?gclid=CjwKCAiAu8SABhAxEiwAsodSZIgrKkXwzzYCJq7A8IJACW-TTPC0_4hlMRPaw1ke-C4BFyDGMyUWTxoCKt0QAvD_BwE Yes there's quite a few processers that can be used. The Loctite 290 is basically a low viscosity resin as well. It's obviously best to get full penetration but anything that seals the porosity is fine. Hence external painting by the factories. Ciao Quote Link to comment Share on other sites More sharing options...
Kevin_T Posted January 27, 2021 Report Share Posted January 27, 2021 I was wondering if x-ray inspection would be cost prohibitive. It would be nice to know what kind of swiss cheese your working with before spending a ton of money. Looking at a few website and what they offer was amazing, but I'm in no position to give them a head for a quote. Some of the images they were showing must have been done with MRI imagining. If they charged what the hospital charges my insurance that's a no go. Kind curious what the minimum amount of information would allow me to move ahead with confidence. Quote Link to comment Share on other sites More sharing options...
Lucky Phil Posted January 28, 2021 Author Report Share Posted January 28, 2021 1 hour ago, Kevin_T said: I was wondering if x-ray inspection would be cost prohibitive. It would be nice to know what kind of swiss cheese your working with before spending a ton of money. Looking at a few website and what they offer was amazing, but I'm in no position to give them a head for a quote. Some of the images they were showing must have been done with MRI imagining. If they charged what the hospital charges my insurance that's a no go. Kind curious what the minimum amount of information would allow me to move ahead with confidence. The usual basic method is to immerse the part in a warm Loctite 290 bath for an hour or so then remove and rinse off. A friend of mine had his E type Jag engine professionally rebuilt a few years back and the engine guy did this with the brand new sump even before it had been fitted due to history of leaks. If you clean a head or crankcase down thoroughly and put it in an oven at 100 deg C any porosity will usually show up with a very careful detailed look or you can buy a Dye check kit and spray the cases with a light coat of the developer only after a thorough cleaning and drying and that will show it up as well. warmed in the oven even better. Any oil in the porosity will be very obvious as it was on my head images. Dye check kits are cheap, probably around $20 us over there and I've used mine more times than I can remember over the years. Ciao 1 1 Quote Link to comment Share on other sites More sharing options...
Kevin_T Posted January 28, 2021 Report Share Posted January 28, 2021 I've of high mileage heads cracking through the valve guides it would great to know if it was caused by inclusion or porosity buried inside the head. For sure what you suggested is in order. I mean that's probably the place to start a project like this. I got to say if hasn't already been said owning and working on a daytona motor is not for the faint of heart. 1 Quote Link to comment Share on other sites More sharing options...
Kevin_T Posted January 28, 2021 Report Share Posted January 28, 2021 I've heard of high mileage Quote Link to comment Share on other sites More sharing options...
docc Posted January 28, 2021 Report Share Posted January 28, 2021 17 minutes ago, Kevin_T said: I've heard of high mileage Oi! My Sport is beginning to resemble that remark! Quote Link to comment Share on other sites More sharing options...
knumbnutz Posted January 28, 2021 Report Share Posted January 28, 2021 When i rebuilt my ducati engine, i wanted the cases painted and so the painter duly sand blasted the cases and painted the exterior. Looked superb too in purple pearl into an almost black main colour. .. anyways, he also sand blasted the interior casing paint off too that ducati use to stop porosity. Before reassembly, i repainted the interior of the cases in a dull red paint specially designed for stopping pososity... can't remember the name but it was easy to come by nor cheap. But it did work a treat and the engine still goes well and doesnt leak after 6years. Quote Link to comment Share on other sites More sharing options...
knumbnutz Posted January 28, 2021 Report Share Posted January 28, 2021 oh... its definitely an italian thing, a friend worked at a maserati/ferrari dealership and he often removed and painted the inside of the engines to stop porosity leaks Quote Link to comment Share on other sites More sharing options...
docc Posted January 28, 2021 Report Share Posted January 28, 2021 So, how big of a thing is this, actually, with our V11 heads in particular? Quote Link to comment Share on other sites More sharing options...
Lucky Phil Posted January 28, 2021 Author Report Share Posted January 28, 2021 5 hours ago, Kevin_T said: I've of high mileage heads cracking through the valve guides it would great to know if it was caused by inclusion or porosity buried inside the head. For sure what you suggested is in order. I mean that's probably the place to start a project like this. I got to say if hasn't already been said owning and working on a daytona motor is not for the faint of heart. I crack checked all my heads for the guide cracking issue. Ciao Quote Link to comment Share on other sites More sharing options...
Join the conversation
