KenBlake Posted May 31, 2022 Report Share Posted May 31, 2022 Hey everyone, I've read that it's common with the V11 transmission to mis-shift. It's been really taking away from the enjoyment of riding and it seems to be a mechanical problem that should be fixed. My question is what would that entail? Which parts would need replacing and it is their a guide for doing so? I have the workshop manual. Thanks! Link to comment Share on other sites More sharing options...
GuzziMoto Posted May 31, 2022 Report Share Posted May 31, 2022 33 minutes ago, KenBlake said: Hey everyone, I've read that it's common with the V11 transmission to mis-shift. It's been really taking away from the enjoyment of riding and it seems to be a mechanical problem that should be fixed. My question is what would that entail? Which parts would need replacing and it is their a guide for doing so? I have the workshop manual. Thanks! I am not the big expert here, but my experience is to first look and the external aspects of the shift linkage. It is fairly common for the external shift linkage to bind or catch, and that can cause shifting issues. To be fair, ours shifts pretty well. And while it is possible to find a false neutral here or there it is rare to actually hit them in use. Usually they are more likely when looking for neutral, finding a false neutral instead of the real neutral. 1 Link to comment Share on other sites More sharing options...
Desdinova Posted May 31, 2022 Report Share Posted May 31, 2022 I've had a Ballabio and a I have a LeMans. Mis-Shifts for me are 90%+ position of my foot. In fact my lever is setup for the boots I wear, and if I wear shoes instead, it's all sorts of problems. Yeah!! I know !!! but seriously. Asjusting the lever position can make a world of difference. The other 10% is when I start to "find" nuetrals, it's because it's either time for an oil change or not enough oil in there. YMMV 3 Link to comment Share on other sites More sharing options...
KenBlake Posted May 31, 2022 Author Report Share Posted May 31, 2022 47 minutes ago, Desdinova said: I've had a Ballabio and a I have a LeMans. Mis-Shifts for me are 90%+ position of my foot. In fact my lever is setup for the boots I wear, and if I wear shoes instead, it's all sorts of problems. Yeah!! I know !!! but seriously. Asjusting the lever position can make a world of difference. The other 10% is when I start to "find" nuetrals, it's because it's either time for an oil change or not enough oil in there. YMMV I didn't even realize I could adjust the shift lever but I'll give that a try! Link to comment Share on other sites More sharing options...
KenBlake Posted May 31, 2022 Author Report Share Posted May 31, 2022 I forgot to mention that I've tried filling the gear box with shockproof heavy as is recommended in these parts but it hasn't solved the problem. Link to comment Share on other sites More sharing options...
docc Posted May 31, 2022 Report Share Posted May 31, 2022 On 5/31/2022 at 3:16 PM, KenBlake said: I didn't even realize I could adjust the shift lever but I'll give that a try! I should be able to find a tutorial with an image of that procedure, but it will be a few hours before I can post it. edit: Well, here is the image, at least. The idea is to get the arms parallel to one another and perpendicular to the connecting rod. Check all the fasteners for tightness. Remove the long pivot bolt (mind the inboard lock nut), clean and grease. Adjust the tension for no binding, or excessive play, and anchor it with the inboard lock nut. I found my pivot benefited from a shim between the shift lever and the inboard frame bracket. Make certain the lever itself is not striking the frame side plate on the downshift or anything above on the upshift. Link to comment Share on other sites More sharing options...
guzzler Posted May 31, 2022 Report Share Posted May 31, 2022 G'day I had issues like this with mine early in the piece too. Having the lever sorted out made a huge difference. Still get the odd one but mostly my fault... ie tired/ foot position blah blah Cheers Guzzler 1 Link to comment Share on other sites More sharing options...
KenBlake Posted May 31, 2022 Author Report Share Posted May 31, 2022 2 hours ago, docc said: I should be able to find a tutorial with an image of that procedure, but it will be a few hours before I can post it. edit: Well, here is the image, at least. The idea is to get the arms parallel to one another and perpendicular to the connecting rod. Check all the fasteners for tightness. Remove the long pivot bolt (mind the inboard lock nut), clean and grease. Adjust the tension for no binding, but excessive play and anchor it with the inboard lock nut. I found my pivot benefited from a shim between the shift lever and the inboard frame bracket. Make certain the lever itself is not striking the frame side plate on the downshift or anything above on the upshift. Thank you! 1 Link to comment Share on other sites More sharing options...
docc Posted May 31, 2022 Report Share Posted May 31, 2022 Here is an image from inboard showing the lock nut without the pesky swingarm in the way: Also shown is the zinc chromate green LuckyPhill/Chuck-made shift extender. There is current interest in a new run of these (highly recommended!): Link to comment Share on other sites More sharing options...
docc Posted May 31, 2022 Report Share Posted May 31, 2022 Alright, a couple more points and I'll pipe down . . . What year/miles is your V11, @KenBlake? There was a recall on the early Sports 1999-2001. Click here to view the recall notice and serial number range. Shims for the inboard side of the lever pivot: And, finally, @Lucky Phil's outstanding "How to . . ." 1 Link to comment Share on other sites More sharing options...
po18guy Posted May 31, 2022 Report Share Posted May 31, 2022 In my '04 Ballabio, I had some air in the clutch line. Thorough bleeding (including a bleeder banjo bolt at the clutch master cylinder) reduced the false neutrals to near zero. Air tends to return to the master cylinder, as it is the high point in the system. So, where did MG put the bleeder? At the bottom! I do need to adjust the shift lever, which is the rest of the problem. 1 Link to comment Share on other sites More sharing options...
docc Posted June 1, 2022 Report Share Posted June 1, 2022 That is a really good point that flushing/"bleeding" the clutch might have an effect on the shifting. @KenBlake, what year/model and miles is your V11? Link to comment Share on other sites More sharing options...
Steve S Posted June 1, 2022 Report Share Posted June 1, 2022 I’ve had 2 Ballabios that suffered with vague gear changes, don’t know why it effects this particular model both were fixed by adjusting the ratchet arm inside the cover by turning the eccentric adjustment and centreing the travel and making sure it clears the casing at the end of travel Link to comment Share on other sites More sharing options...
KenBlake Posted June 25, 2022 Author Report Share Posted June 25, 2022 On 6/1/2022 at 12:54 AM, Steve S said: I’ve had 2 Ballabios that suffered with vague gear changes, don’t know why it effects this particular model both were fixed by adjusting the ratchet arm inside the cover by turning the eccentric adjustment and centreing the travel and making sure it clears the casing at the end of travel Can you link to a tutorial on this by any chance? Link to comment Share on other sites More sharing options...
KenBlake Posted June 25, 2022 Author Report Share Posted June 25, 2022 On 5/31/2022 at 5:02 PM, docc said: That is a really good point that flushing/"bleeding" the clutch might have an effect on the shifting. @KenBlake, what year/model and miles is your V11? It's a 04' Ballabio. Thanks! Link to comment Share on other sites More sharing options...
