If you have one, let me know.  Thanks!
In tank or external? Both are common as mud and can be bought on Ebay and Amazon with fuel line, filter and clips as a package for the internal pump models.
Phil
Dealer said 500+ $ for internal pump 8years ago. Bought 2 Quantum pumps for 150$. NO problem so far.
Cheers Tom.
My original 2000 V11 Sport external fuel pump measures 111mm long by 55mm diameter (across the body where it mounts).
The fuel pump I got from MG Cycle ("replacement for Bosch"/ "Quantum") is 112mm long (body between hose connections) and 52mm diameter.
Three years ago, it was $55US, before shipping/taxes. I never installed it after I found my fuel pump issue was relay related. :rolleyes:  :whistle:  <_<
[edit: I see the price has not changed ($54.56US).  There are no stampings or markings on the part and I see nothing on the website.]
Here is where I got the "Quantum" name:
https://www.highflowfuel.com/fuel-pump-oem-replacement-hfp-603-qfs/
HFP-603__86414.1747366187.jpg?c=1
[edit #2:  Flow Rate: 190LPH;  I could not find a flow specification for the Moto Guzzi external pump.]
Posted (edited)
yup, my AliExpress pump is working perfectly. Most pump sources are buying these very same pumps, and upselling them.
Edited by LaGrasta
I've had the Quantum pump on mine for...7 years? and about 15k miles. iirc Quantum has a meaningful warranty.
Posted (edited)
Did the Quantum pump fit the rubber insulator that held the factory pump ?
 M/G did not make the pump they sell , they farmed it out just like all other companies .
Edited by gstallons
It does; mine was frame mounted, I installed it across the front in the airflow. The body is just a tiny bit smaller, so it's not as tight as the stocker but good.
you can stuff some kind of filler in there
