swooshdave Posted 3 hours ago Posted 3 hours ago I rode over and met some guys for lunch today. Beautiful weather. As I headed off to come back home the bike sputtered and then died. I checked and there was gas. I restarted it and it was mostly uneventful on the way home. The oil pressure light came on for a second but then immediately went out around a corner. I will admit I treat this thing like a Honda. Put gas in it and ride. There's probably a maintenance list that I'm completely ignoring. That might be catching up to me... I should probably change the oil (not because of age but miles). Or at least check to see if it has oil. I suppose my biggest fear is the original fuel pump will fail at some point. At least I think that's my biggest fear. 1
gstallons Posted 3 hours ago Posted 3 hours ago Red frame ? Whewwww. it could be ANYTHING . We will put on our thinking caps and come up with some suggestions and things to check ! 2
audiomick Posted 3 hours ago Posted 3 hours ago (edited) 36 minutes ago, swooshdave said: the bike sputtered and then died...there was gas. I restarted it and it was mostly uneventful on the way home. 24 minutes ago, gstallons said: ... things to check ! Firstly, and easiest to check: the switch on the side-stand, the switch on the clutch, the kill-switch. All those "safety features" that will stop the motor if they have a fault. Check them and make sure there is nothing dodgy, and take it from there. Oh, and have a look inside the ignition switch. After that, the relays, primarily those involved in the safety features. But as @gstallons already wrote, there is a whole list of things it could have been. Maybe even "only" a bit of water in the fuel tank. Edited 3 hours ago by audiomick 1
swooshdave Posted 1 hour ago Author Posted 1 hour ago 1 hour ago, audiomick said: Firstly, and easiest to check: the switch on the side-stand, the switch on the clutch, the kill-switch. All those "safety features" that will stop the motor if they have a fault. Check them and make sure there is nothing dodgy, and take it from there. Oh, and have a look inside the ignition switch. After that, the relays, primarily those involved in the safety features. But as @gstallons already wrote, there is a whole list of things it could have been. Maybe even "only" a bit of water in the fuel tank. Would the side stand cause it to sputter and then die? Or just die immediately? I didn't touch the side stand when I restarted it. I did touch the side stand switch wiring recent to clean up the routing. Relays were addressed when I got the bike. It sputtered like it was out of gas which made me think fuel pump since it had gas. But my experience with fuel pumps is they just keel over (although I've had some that you could tap with a hammer to get them to start back up).
footgoose Posted 43 minutes ago Posted 43 minutes ago my first thought is gas. either nasty or water. depending on the level of neglect, could just be condensation. (cuz where you live) If it's been awhile you may want to drain and flush the tank.
pete roper Posted 34 minutes ago Posted 34 minutes ago If the oil light came on briefly it’s bad news. It is likely low on oil. Does it have a sloppage sheet fitted? 1
