docc Posted yesterday at 03:42 AM Author Posted yesterday at 03:42 AM 1 hour ago, Speedfrog said: I think a good all purpose grease should be sufficient for that. I’ve been using Super Lube Synthetic Grease lately and I like it a lot. Heh, mebbe good, then, having used this . . . 1
gstallons Posted 17 hours ago Posted 17 hours ago Pretty good stuff. Everything they sell is top notch. 1
Scud Posted 16 hours ago Posted 16 hours ago 12 hours ago, Speedfrog said: Kluber Staburags is not so easy to find! Doesn’t roll off the tongue as easily either That product is readily available wherever old BMW motorcycle enthusiasts gather. And it doesn't roll off anything. I learned about it when I had a K75S. Applications to the BMW drive shaft splines border religious ritual among the "faithful." 3 1
audiomick Posted 13 hours ago Posted 13 hours ago A word to the wise: although *everyone* just refers to "Staburags", the letters after the name are important. There are quite a number of products called "Staburags xxx", all with a different intended purpose. https://www.klueber.com/de/de/suche/?q=STABURAGS#suchergebnisse 1
docc Posted 9 hours ago Author Posted 9 hours ago 5 hours ago, audiomick said: A word to the wise: although *everyone* just refers to "Staburags", the letters after the name are important. There are quite a number of products called "Staburags xxx", all with a different intended purpose. https://www.klueber.com/de/de/suche/?q=STABURAGS#suchergebnisse I see this for the NBU 30 PTM that I ended up with. I reckon that is the right stuff for the drive hub. "Lubricating and assembly grease STABURAGS NBU 30 PTM is a solid lubricant-containing, water-resistant assembly grease that protects against tribocorrosion (fretting corrosion and fretting corrosion). It is particularly effective for outdoor applications with high humidity." 1
Pressureangle Posted 9 hours ago Posted 9 hours ago 19 hours ago, docc said: A mechanical, dial actuated, combination lock. I am rather surprised at the "high speed, load carrying, and water resistance" characteristics for this application. I will personally vouch for this; Loosens ridiculously siezed locks, to wit; 30 years unused security door latch in El Paso. Applies easily, not sticky, doesn't linger on finger, and critically important; DOESN'T STINK. https://www.superslickstuff.com/product/houdini-lock-lube/ 1 2
docc Posted 8 hours ago Author Posted 8 hours ago "No Teflon. No Silicone. No grease. No oil. No graphite." WTH is it? 1 1
Pressureangle Posted 8 hours ago Posted 8 hours ago 25 minutes ago, docc said: "No Teflon. No Silicone. No grease. No oil. No graphite." WTH is it? F'n Magic, bro. "Any sufficiently advanced technology is indistinguishable from magic" -Arthur C. Clarke 2 2
Lucky Phil Posted 8 hours ago Posted 8 hours ago 38 minutes ago, docc said: "No Teflon. No Silicone. No grease. No oil. No graphite." WTH is it? Well the SDS says a "propriety blend of base OILS and solvents". So much for the "no oil" bit on the can. Phil 3
docc Posted 6 hours ago Author Posted 6 hours ago I got a can of Houdini on the way. I am trying to restore smooth turning of the combination dial without disassembly. Or hiring a locksmith. The lock manufacturer notes "Heavy petroleum lubricants can cause swelling and distortion of Delrin or Celcon (plastic) components. Use only recommended lubricants (AeroShell, Versilube, and Gn Metal Paste). " https://sargentandgreenleaf.com/knowledgebase/knowledgebase-2017-02-24-lubrication-points-for-the-sg-6700-series/ 1
audiomick Posted 5 hours ago Posted 5 hours ago 3 hours ago, docc said: ...NBU 30 PTM .... I reckon that is the right stuff for the drive hub. ... Yes, I believe that is indeed the particular variant that is named for the cardan and drive hub by those who bother to quote the xxxx after the "Staburags" name. 1
Pressureangle Posted 4 hours ago Posted 4 hours ago 3 hours ago, Lucky Phil said: Well the SDS says a "propriety blend of base OILS and solvents". So much for the "no oil" bit on the can. Phil I'm sure that OSHA, FDA, API, and the Commerce Department have space between their thresholds for naming something 'oil' lol 1
po18guy Posted 3 hours ago Posted 3 hours ago On 11/14/2025 at 5:33 PM, docc said: A mechanical, dial actuated, combination lock. I am rather surprised at the "high speed, load carrying, and water resistance" characteristics for this application. Sweaty thieves in a hurry? 1
po18guy Posted 1 hour ago Posted 1 hour ago 7 hours ago, docc said: "No Teflon. No Silicone. No grease. No oil. No graphite." WTH is it? What's left other than micropulverized mica?
