stewgnu Posted August 4, 2018 Share Posted August 4, 2018 Ok ok ok, so who here is running a v11, regularly likes, that exhibits an oil leak? I am. Link to comment
docc Posted August 5, 2018 Share Posted August 5, 2018 Last year, I finally buttoned all mine up. After putting up with them for years and years . . . 1 Link to comment
leroysch Posted August 5, 2018 Share Posted August 5, 2018 My 2004 has never marked her spot. Link to comment
LowRyter Posted August 5, 2018 Share Posted August 5, 2018 ..........mine has had a cracked tranny and a leaking front seal and timing cover gasket. Link to comment
footgoose Posted August 5, 2018 Share Posted August 5, 2018 the '02 started dripping onto the xover 3 years years ago. it was a disintegrating case/frame vent tube. the '00 I just got into my life is doing the same. It's SO obviously a rotten vent tube, again, onto the xover. The '02 also leaked from the timing sensor. None of the leaks made it to the floor. Link to comment
czakky Posted August 5, 2018 Share Posted August 5, 2018 Ive had several. Timing cover gasket, front crank seal, timing sensor (a few times), crank vent tube, rear drive seal (fingers crossed the big outside one will hold) and the one I haven’t got yet is the rear transmission not a gasket housing. None marked territory... I don’t count the valve covers either. Link to comment
stewgnu Posted August 5, 2018 Author Share Posted August 5, 2018 My 2004 has never marked her spot. Are you sure you’re on the right forum? 1 Link to comment
stewgnu Posted August 5, 2018 Author Share Posted August 5, 2018 Timing gasket leak, poss weeping from the crank sensor hole, and poss one other as yet undiagnosed.... Parked up she puts a ‘coin’ of black down now, the dirty girl. Link to comment
bbolesaz Posted August 6, 2018 Share Posted August 6, 2018 None, other than the day the crankcase ventilation line split in two while rolling down the freeway. Then it was like a crop duster mated with the Exxon Valdez. Link to comment
Tom M Posted August 7, 2018 Share Posted August 7, 2018 None, other than the day the crankcase ventilation line split in two while rolling down the freeway. Then it was like a crop duster mated with the Exxon Valdez. Me too. Link to comment
docc Posted August 8, 2018 Share Posted August 8, 2018 Here is a sampling: Four year running oil leak thread on the "Bell Housing Leak ": https://www.v11lemans.com/forums/index.php?showtopic=18243&page=1 LowRyter's "Gearbox Drip (case crack)" thread: https://www.v11lemans.com/forums/index.php?showtopic=19814 Scud's tutorial "Re-seal a 6-Speed Transmission ": https://www.v11lemans.com/forums/index.php?showtopic=20021&hl=%2Bseal+%2Bsix+%2Bspeed Eight year thread on "Rear Drive Seal ": https://www.v11lemans.com/forums/index.php?showtopic=15908&page=1 Ten year thread "Oil leak " on leaks up front: timing chest, timing sensor (#112 O-ring), and even the wire lead from the timing sensor: https://www.v11lemans.com/forums/index.php?showtopic=10719&page=1 This does not include potential fork and shock leaks or leaking from the steering damper . . . Oh, and that pesky O-ring on the head bolt under the rocker shaft that keeps staining my head fins. Link to comment
docc Posted August 9, 2018 Share Posted August 9, 2018 oooh my.......... Gosh, I guess I should clarify that my Sport hasn't had all of those leaks. That was sort of a compendium. Admittedly, my Sport may be over-represented in the leak threads . . . Link to comment
Chuck Posted August 9, 2018 Share Posted August 9, 2018 The mighty Scura has been abused sit for long periods ran hard set for long periods Etc. Never a drop.. of course now she is jinxed. Link to comment
docc Posted August 9, 2018 Share Posted August 9, 2018 The mighty Scura has been abused sit for long periods ran hard set for long periods Etc. Never a drop.. of course now she is jinxed. Say three Hail Marabeses and call me in the morning. 1 Link to comment
