Tinus89
    7
Everything posted by Tinus89
  1. Thanks for those links! Which are the splines Luigi forget to grease, the forward (requiring swingarm removal), rear or both?
  2. I have known Luigi from my V11 and will check & grease the splines. Does this require the front clamp connection to be broken and then slide out towards the bevel drive? Or does this mean swingarm removal? Another question: my dad's CalVin has twinspark. Am I correct these spark plugs are different? The manual only states BPR 6ES, but Stein-Dinse states the inner one is PMR8B. Is this correct and if so, should the inner one be gapped at 0.7mm as well?
  3. Excellent advice, thanks! I'll PM you for those maps. One question on maintenance: the rear drive shaft on this bike is the enclosed/covered type. What maintenance does it require, if any?
  4. Thanks a lot for the responses! Some answers from my side: - The bike NEEDS a full service and tune anyway, it has been over a year. Fluids/filters, valves, TPS, synch, the works. - I will also change the fuel filter so I will have a look at the lines in the tank as well. - The 15RC ECU can be read out using Guzzidiag, so I assume I can also read and adjust the map (I have experience in this on my V11 to solve light pinging) - The bradthebikeboy tune is already on my desk as a print out:) I'm familiar with Guzzidiag and TuneEcu. If the tune up does not solve the pinging, can I add some fuel to help it in that area where she pings (this solved it for my V11) or does that only work on an open loop map (no Lambda)? If so, any clues to where I may find a good Open loop (no Lambda) map as a starter?
  5. They may have faded from the heat, but funny enough my Mandello Rosso has that as well. The porkchops do the same (but less), and the tank and seat cover stay nice and red. It almost seems like the paint on alu parts does not hold as well as on the plastic parts.
  6. I have sent him a message a while ago, but no response yet. In the mean time, roadside assistance brought the CaliVin home. Empty battery. I diagnosed her yesterday: molten 30A fuse (second time, I discovered it was already in a separate fuse holder, done by the PO). I'll replace the fuse holder and also give her a full service in a few weeks time.
  7. Not knowing your knowledge on V11's, and certainly not knowing all differences by head, I do feel the need to warn you about the (factory) single plate clutches. These are found on Rosso Mandello's and Scura's, maybe on others as well. [docc edit: + Tenni ] I also do not know whether this applies to all factory single clutches or a certain build time. They have a habit of desintegrating (exploding through the engine casing) due to fatique-cracking on the aluminium flywheel. Look for one to be converted to either a twin plate clutch, or a aftermarket single plate with flywheel (e.g. RAM clutch). Edit: or convert it yourself of course! When it comes to V11 versus the other Guzzi's, most definately a V11.
  8. I have been struggling with something similar, having to take off the tranny twice again. What had happened was that one or two of the springs behind the spring plate were not seated properly, not allowing the clutch to disengage. The leaver did feel a bit stronger/harder than normal, but not enough for me to realize this was it. Only after finding the springs and reassembling, I also noticed the difference in clutch feel.
  9. I also don't hear anything out of the ordinary (outside of the dog wanting attention)
  10. That same shop refurbished (polished) and rebalanced my crankshaft & conrod/piston assembly. Indeed, he is very knowledgeable. They race with Duc's themselves.
  11. Intent was to do a full service first, if required (history-based) change the filter as well (it's an in-tank unit, isn't it?), but why are you suggesting to measure fuel pressure? Once the revs are up high enough, she pulls as expected. The pinging is only on >50% throttle at rpm 3000-5000, after that it's gone as well. It needs a full service anyway, as last was 02-2019.
  12. Anyone else who has some knowledge about the TPS setting and readout using GuzziDiag? I don't live near the bike...
  13. My dad has one of these, and it runs lean. Lean as in pinging. I've offered to do a service (oil/filters/valves etc). My question is: can I also read out this ECU using Guzzidiag and my V11 cable? Is the ECU also a 15x unit like the V11? Does anyone know the TPS settings?
  14. - Removal of transmission from engine - Untorque input hub transmission - Remove rear cover bolts and rear plate complete with all shafts comes out.
  15. Actually you may want to consider checking the clutch is free. I've had a friend with a Cali III FI whom's clutch fused together in sitting just 8 months. If your gearbox is out as well, just connect the engine and gearbox together with 4 bolts and connect & bleed the clutch lever (next to the bike) and see if she declutches. If that works, all fine. If the gearbox is out anyway, should take less then an hour and no need for special tools.
  16. Yesterday evening I disassembled and cleaned the entire carbs (carb cleaner + compressed air trough all galleries/jets). Nothing worrysome to find. Reassembled and restarted: exact same behavior. I'm considering temporarely swapping L/R to see if the problem moves with the carb. Define "hanging up"? It runs fine with the choke closed...
  17. Correct. Cold start without choke is fine (on the throttle to keep her running the first 3-5min), as soon as I choke she dies on the LH cylinder.
  18. V65 Florida, Dellorto PHBH 30 carbs.
  19. Hello people, As my V11 and Caponord are going towards "finished" (read: reliable), and this COVID-19 has ruled out most social things as well as holidays, I've decided to start a dream of mine: build a cafe racer scrambler. The victim (and thus my 3rd bike) is a V65 Florida with 45.000km. She runs fine, but is in need to TLC (and stripping). Oh and yes, that guy is me I'll probably mostly use this topic for the build progress (it will be multi-year project) and technical questions, simply because this is one of the best forums in the world! So far I've done a little tune-up and rode her for 150km, just for a shakedown. Question: I've worked mostly on FI bikes. This one had a stuck choke cable (in the LH carburetor), which I worked free. However, when I apply choke when she is cold, the seems to drown in fuel on the LH cylinder. I've already flushed the LH carburetor, what else can I try? Disassemble and ultrasonic bath?
  20. KINDOY2, what have you done to the header pipes to make them this black?
  21. Actually, I have to admit something. My clutch isn't entirely V11 twin-plate. Because when I did the mod, I could not source a V11 twin-plate flywheel. Here is what I did: - Aftermarket steel V10 Centauro flywheel - Lemans starter gear (I think the latest Lemans before the V11, but unsure. It was a used part) - All other parts V11 twin clutch (new) except for the intermediate plate (used, but V11). To make this fit I used 8mm/m6 guide bolts (starter gear was M8, flywheel M6). The reason I hook onto this thread with my remark about the absence of rattle, is that my clutch engages late. I mean really late. I suspected the pushrod, but lately found out that is not the issue. So I suspect my modified clutch (now has 10.000km of experience) is a bit too loose when engaged (i.e. plates compressed). For this I suspect two possible causes: - Weak springs, I may have to go to either alternating weak+strong, or 8x strong. - Too much room in the clutch due to the combination of parts not being standard... I have the feeling my clutch will maybe last another 5-10k km. When it starts to slip, I will have to go and investigate....
  22. Nope, it did not have that mount. It does now Yes, I added this plate Docc. It does. Unless you weld a mount on the frame to receive the plate, like I did.
  23. I like your venture... However: my Rosso has been converted to a twin-plate setup. I must admit, not a standard one, but for sure twin plate. So is it fair to assume a twin-plate V11 clutch should not rattle when engaged (in neutral)? Because mine does rattle when engaged...
  24. Glad she is OK! I did a similar thing on my black frame V11, left side as well, which cracked my gearbox directly adjacent the top rear mount. May want to check for that. Mine does not have the mid engine-gearbox-frame mount (well, it didn't then, it does now. And a new gearbox), I'm sure it would be fine if it has it.
  25. Leave the middle bolt loose so it can slide, turn the bars to full lock left, move the damper all the way until it bottoms out, move it back by 3-5mm, tighten middle slider nut? @knumbnutz: how come your V11 does not have any clutch rattle?
