swooshdave
    68
  1. Remember, silver bikes are just green ones they forgot to add the green tint to...
  2. The photo was pretty dark which made it more difficult. And that red is a tough color to match on a good day. But this should be close:
  3. I tried to but it's crowded up there. But I also didn't try very hard. I'll look again.
  4. I believe one of mine has been replaced and the needles don't match. There are markings on the back on the instrument that says something like "Used Checked Good" or something.
  5. There's a ground wire on the regulator. Is this stock or did someone add it? Sent from my iPad using Tapatalk
  6. I got the new Michelin Pilot Road 4 on the front. Extremely sticky. Can't wait to try it in the wet. Actually I can wait... Sent from my iPhone using Tapatalk
  7. Are new bezels not available? For Smiths they use an elaborate contraption to roll the crimp back on. You can also do it if you have a lathe.
  8. Paint them orange and then a UV resistant clear.
  9. My torque wrench does ft lbs and kgs. Those might equal NM but I just went with what I knew.
  10. Yeah, you'd just expect the brake calipers to be explicitly listed. Strange that in the owner's manual they tell you how to take the front wheel off but don't tell you the specs to put it back together. I put mine at 37 ft lbs. Sent from my iPhone using Tapatalk
  11. In my copy of the workshop manual Section F Page 18 it doesn't specify the torque for the front calipers. Nor in the Torque Specs Section B Page 12. This is the 03/01Version. Where did I miss it?
  12. Reply with a nice big photo of your bike, please.
  13. Don't take 97 the whole way and you'll be fine. Better yet take 101. There are some rough spots where stuff has washed out but most of the time it was a blast.
  14. Ok. The muffle mount was hitting the fender so I took it all off and pulled the footrest out. I should be good now. Sent from my iPhone using Tapatalk
  15. Great. More bent parts. Did the cast aluminum piece bend or did the muffler bracket? Or both? Sent from my iPhone using Tapatalk
  16. Has anyone ran no crossover and what did that do? Sent from my iPhone using Tapatalk
  17. I tried to straighten the bolt a little and then it didn't hit the switch with the lock nut on. So I took it off. It's in my growing box o' Greenie parts.
  18. Got the bike in the air in preparation to get a new front tire on. Great chance to look under the bike and see what's what. Side stand switch bolt bent. I'm surprised it still worked. Adding that to the list. More serious is the loose seal. I see the forks coming off in the near future. Workshop manual says use special kit to get front spindle out. Great. Take off the plug and see a giant hex. Fortunately over the years I've collected a lot of tools and had the exact right size. Still waiting for the lift to show up today. Sent from my iPhone using Tapatalk
  19. Shoot, pay for plane fare to Spokane and then Bay Area up to PDX, plus gas and I'll ride the dang thing down for you!
  20. I loosened the high idle screw and then used a shim (piece of thin cardboard) to set the distance. You don't want the part to touch the cam. Just clear it. Too close and when you open the "choke" on the handlebar it will rev too high. Too far away and it won't rev enough. So I've also read that only using the left side for your idle can lead to inconsistent idle speeds as you are relying on the linkage to manage the idle on the right side. Ideally you would set the idle screws exactly the same. I'm going to try this method.
  21. I won't be able to get to this stuff until Monday but keep up the great ideas! Sent from my iPhone using Tapatalk
  22. Yeah, I set mine to 15 and like it a lot. Maybe docc should set his up from zero and see what happens...
  23. What did you set the CO to?
  24. The nice thing about Photoshop is you can make changes and they don't cost a thing! See, carbon fiber side panels and red valve covers! It was quick too! Anyone want to have some free mods? Post a large photo of your bike with your request! Sarcastic requests will be met with brutal results.
  25. This is a left and a right. You can see the ends are the only difference. Sent from my iPhone using Tapatalk
