swooshdave
    65
  1. Didn't I do that? Sent from my iPhone using Tapatalk
  2. I think it has a headlight, LED. Might be some hidden turn signals too. Stock mufflers are crazy heavy, along with the wheels. 30lbs for a frame is reasonable although you could trim that down a bit. Especially that rear subframe. Sent from my iPhone using Tapatalk
  3. You can bypass the Sidestand Switch by simply shifting into neutral. And then you could have a bad Neutral switch? Do you remember the good old days when the fanciest thing you had to worry about was if your Boyer was going to fire?
  4. Side stand could have been knocked down from the impact, which looks to be substantial.
  5. The headlight won't make a dent. I'd be more interested in a HID if the headlight shell can take the heat.
  6. Is it really that weak? I have LED bulbs in my vintage bikes because they are actually weak and every amp counts. The V11 seems to be putting out decent voltage barely off idle. What it is the amp rating on the alternator?
  7. No one mentioned this but maybe the side stand switch? Bypass it and see if you still have a problem? That's where it seems to have started.
  8. Light works great! Ignoring the light for too long... not so much. It started to flicker and I thought about getting gas. Wife texted me and asked me why I wasn't getting the kid from daycare. So I headed home asap. I thought I had enough to get home but it started to sputter and I was in the countryside and away from a gas station, I managed to make it to the nearest gas station but if it had been a few more feet I think I would have been pushing it. Luckily the last 1/2 mile was downhill. They didn't have a reserve on EFI bikes because they assume if you don't pay attention to the light it's your own damn fault.
  9. All that matters is that you're ok, bike and bike parts can be replaced.
  10. Bodywork is aluminum.
  11. What does the stock spine frame weigh?
  12. @Cash, I can't get that to link. Could you give it a look? https://www.thirdgear.com.au/motorcycle-hid-xenon-35-w-bulb-kit/ Someone forgot the "m" in "com". Not sure how that happened.
  13. I didn't see any posts for either titanium or the builder's name. http://thebikeshed.cc/2017/05/04/paul-milbourn-customs-moto-guzzi-titanium/ 155kg WET. 340lbs... I though the powertrain alone weighed that much! This guy is bonkers brilliant.
  14. This is the one I put in the 850-T. Mind you it only has one element so you may not like the light pattern. I ride that bike during the day so it's ok. Safego Motorcycle H4 LED Headlight Bulb H/L High Low Dual Beam 20W 2000lm Motorbike H4 LED Lights Kit M4-H4 https://www.amazon.com/dp/B01C1AOSVS/ref=cm_sw_r_cp_tai_8vtgzbJGM8BFX It does have a fan but I'm ok with that. And it was shallow enough for that bucket which is not deep. In order to fit the shallow bucket the cooling mechanism may need to be inside. Here's another option. RTD LED Motorcycle Headlight Bulb H4 Motorcycle Front Lights with Cooling Fan COB Motorbike Headlight 20W Moto Bulbs Hi/Lo Beam LED Headlamp Light Bulb for Honda Suzuki Yamaha Kawasaki Pack of 1 https://www.amazon.com/dp/B01MPXS2KS/ref=cm_sw_r_cp_tai_LAtgzbHNSTPTW
  15. https://www.ebay.com/itm/162075704243 This might work too.
  16. No. Don't ask me how I know.
  17. I ran my tank dry (it sputtered for a couple miles). I was only able to coast into a gas station by flipping the bike left and right as I rode. That helped splash the gas around inside the tank. If you have an external fuel pump can't you put a tap on both sides of the tank?
  18. There should be an understandable hierarchy of tool grades. Something like: >HF & Chinee online >Local hardware store >Tool truck/ Professional Quality >Marine Grade >Aviation Approved >Space Program unobtanium-made I use this crimper extensively. Has never failed me. https://www.harborfreight.com/ratcheting-crimping-tool-97420.html $15 not on sale. Although these are the ones I use the most. GM Delphi Weatherpack Crimper Tool https://www.amazon.com/dp/B005K006QS/ref=cm_sw_r_cp_api_f2pgzbY44M70R
  19. Did you just get one off eBay?
  20. Did the Scura fairing come with something on the lip of the fairing from the factory? Sent from my iPhone using Tapatalk
  21. I like the blue and white too. I'd love to take another crack at it with a better picture. Preferably less dark but also not in direct sunlight. Early morning or early evening would be best. Sent from my iPhone using Tapatalk
  22. Not so much a laugh, more of a "what's the matter, this is how it's suppose to work!" Sent from my iPhone using Tapatalk
  23. How do you know it's a Scura? Sent from my iPhone using Tapatalk
  24. Sounds about right. Sent from my iPhone using Tapatalk
  25. http://www.v11lemans.com/forums/index.php?showtopic=14530 sport 1100 guzzi ignition sensor site:www.v11lemans.com http://www.v11lemans.com/forums/index.php?showtopic=16937 http://www.guzzitech.com/forums/threads/modern-no-start-issue-solution.4908/
