Rear drive needle bearing and swing arm restoration
Lucky Phil replied to Bjorn's topic in Technical Topics
Never put off till tomorrow what you can do today. Every time I put something off it bites me in the arse. Ciao -
Now you make me feel bad cause I'm always moaning about the Melbourne winters. Having said that I'm always amazed at the weather some others have to endure. Someone posted a while back either here or wildguzzi about an ice storm at their place. I wouldn't survive weather like that or heavy snow in winter, too soft. Ciao
Not unless it has been subject to intense sun or ozone. Most of the stuff we get these days has been on a shelf somewhere for years. Ciao
You can send it to me if you like but your brother might be quicker. Ciao
It will be a simple lip seal docc. Measure it up and off to the bearing shop. ID + OD + width and material. Ciao
Fitted the new carbon rear hugger and at the wifes suggestion went for a ride on a nice sunny day. Ciao
It took me a while to design it, I'm not fast like that. All the fasteners and bushes are Titanium. The 4 nuts on the on the 6mm fore/aft adjustment bolts are superficious and I may remove them at some point for a neater look. The base of the vertical legs rest on the frame top rail to control any possibility of any rocking movement. I wanted something that could be restored to original without any welding etc. Ciao
Reviving an Old Garage
Lucky Phil replied to Kane's topic in Special place for banter and conversation
I've gone to a high quality Head light docc. Adjustable so it shines exactly where you are looking and if you get a good one with built in charger it gives 15 hours of very bright lighting. Wish they made them when I was working under the cowls of hi bypass gas turbines out in the open tarmac for 30 years of my career. Ciao -
I wouldn't agree with that statement personally. Ciao
Yes same as when our hangar floors were coated in a white finish. So much brighter even with the original hangar lighting. Ciao -
It's a round ring like a donut that fits on the shock shaft so when the shock approaches full travel the eye end doesn't contact the shock body cap. You wont be able to buy one for a Sachs shock so you'll need to go to a suspension specialist and see if an Ohlins or another brand will work that can be purchased as a spare part. Ciao
Silicone isn't fuel resistant. Ciao
Panelling for looks, insulation, light reflectivity, cleanliness, dust mitigation and some additional security. Plus it just makes for a nicer working environment. Ciao -
Yep thats it the shock full travel bumper. Horrible to replace. The spring needs to come off the shock and the eye end removed. I've had to get this done before, quite tricky. Ciao
Through the wiring it can I think Ciao
Don't think so. He means the fuel vent and overflow hose I think. Ciao
Probably would be there's quite a bit of room under there now which helps the cooling but I'll see how it goes. Its in a way better location than my 1198 and they seem to last ok. Ciao
Here's what I did with the V11/V10 front tank mount. I could design a simpler setup for a std V11 with fore and aft adjustability but it would raise the front of the tank maybe 10mm which wouldn't matter and probably be hard to pick. My V11/V10 mount raised the tank 40mm which was necessary so I thought I may as well make it adjustable. The tank sealant I used on the commercial jet fuel tanks for 40 years was PR-1422. The "A" was the runny one and the "B" the non runny version. Ciao
The std tank benefits from greasing the rubber pucks when installing the tank. My greeny tank is the same size as the day it left the factory, never seen ethanol though. Ciao
Yes Chuck that's a good example as well. Old race engines are generally RPM limited as well when the cases get to a certain age and it becomes impossible to find replacements. It's just the nature of the material. doesn't affect most people because old engines are generally used on old road bikes and aren't under enough stress to cause an issue so they are still over engineered for the application. Start hammering them in classic and post classic racing and things are a bit different. Ciao
Aluminium alloys dont become brittle because they are sealed from oil. They get brittle because they age. That's the nature of aluminium alloy it hardens with age. Ciao
Not sure docc but the l/h head on my original engine was affected and a mates MK4 Le mans had porous crankcases around the r/h cylinder base. Plenty with Ducati's. You'll know it if you've got it, an oil leak you just cant seem to fix is the clue. Ciao
I crack checked all my heads for the guide cracking issue. Ciao
