Just to let people Know Joe is producing his V11 Steel timing gears again. Contact ....joe.caruso@ntlworld.com I have a set and can vouch for their quality, although I havent gotten around to fitting them. They are so nice seems a shame to hide them inside the engine:) Heres an historical link. BTW I have no commercial interest here, just supporting quality engineering. http://www.v11lemans.com/forums/index.php?s=aeffc913faaff2a5845e6e6f02bf4770&showtopic=18899&page=2 Ciao
I use the same levers on my Ducati 2003 1000ss, 2000 V11 and 2001 Ducati ST2. Ciao
Im not surprised you saw something odd. With two voltage meters I wouldnt expect anything less. I think you also need 2 oil pressure gauges to make you riding and ownership experience complete. Ciao
Timing Gear Set - Replacing timing chain
Lucky Phil replied to FalcoLion's topic in Technical Topics
A chain is actually a more efficient transmitter of power than a gear train. Typical chain losses are around 1%, gears around 3% or more. Ciao -
Timing chains lack engineering "elegance". Much better for using in the drive line though. Ciao -
No question is dumb so here goes: Anybody ever paint their forks?
Lucky Phil replied to Goosed Again's topic in 24/7 V11
Just get them anodised, cheap, robust available in a million colors and wont increase the fork Dia. Just need to strip them down to do it. Put in the effort and do it right. Ciao -
Thats horrible. Ciao
The later tail sections are definitely different material from the early units. I havent actually looked on the inside at the material markings but would bet they are ABS or PP. I also have a later model pillion seat cover and pad and it appears identicle to my early type. ciao
Timing gears are also available for the 1100 motors Ciao -
No they're not actually. The early 1999-2000ish like my bike have a heavy tail assy made of some sort of composite material with internal walls on the side for want of a better explaination where the later versions 2003 and later (maybe) are a light and quite flimsy (more modern style) of ABS and just a single skin on the sides. I have both at home, the latter off a Balibio and it looks like it will fit on my 2000 year model spare subframe without any issues. The later type also uses an additional removable bracket at the rear for the rear mount positions. Ciao
You know I didnt actually check the diameter of the shifter fork boss when I got the kit,probably should have I guess. I worked on the assumption that if Guzzi was producing an upgrade kit with a new shifter fork assy included then it would be the type with the reduced boss dia. The major changes seem to be the addition of an accentric and the banana link connecting the 2 gear wheel shafts. I dont really know why they even included the new shifter fork assy as it seemed to be no different to the original one in my bike which had the smaller dia boss. I just assumed that they included the latest reduced dia boss shifter fork assy as a precaution in case you had the faulty type. From my understanding the larger dia boss on the shifter fork that causes spring breakage was due to a manufacturing defect. ie a bad batch, not a design problem. Thats why the earlier bikes didnt suffer. Ciao
40,000klms, its shifting was acceptable but not brilliant, and the lever used to stick for a fraction of a second on completing an upshift occasionally. I had replaced the return spring previously. BTW I refilled the trans with the same oil which was only 1500klms old so new oil wasnt a factor. Ciao
Its a factory guzzi part/kit, p/n 973260900017. Bought mine from Harpers Moto Guzzi Ciao
Tried uploading by various methods from photobucket by the forum wont allow? If someone can help I have photos which demonstrate the differences Ciao
Well I finally got round to doing my gearbox shifter upgrade and took the bike for a run this morning. I'm a pretty hard marker with these things and dont believe in talking up something that doesnt work even if it has cost me money. The kit comes with a new cover ( with additional eccentric adjuster), shifter fork, return spring a banana plate and replacement detent arm pivot and no selector shaft seal. Its a fairly easy task to transfer all the original parts that are going to stay to the new cover. As the photos show the new accentric seems to be there to limit the shifter fork assy from too much sideways movement. The original cover had a non adjustable roll pin for this purpose that gave about 1.5mm clearance to the arm. I set the accentric to give about 0.2mm clearance to the arm at a minimum during shifting. The main accentric was also adjusted of course so that in 2nd gear and upwards selections the shifter fork hooks were centered on the drum pins. So whats it like? is it worth the trouble and cost ( kit cost is $125us) Remember my bike is a 2000 model and I believe the 2003 and later bikes already have this system as std. Having said all that its a definite improvement. Shifting is more precise and solid, shifting with or without the clutch ( I usually up shift from 2nd gear on without using the clutch) probably as good as my Ducati's now. So its for each person to consider the worth I guess. Ciao
Pete I was listening recently to a well known radio presenter that had come up with an inovative design for something and when he investigated the possibiltiy of going into production the professional advise he got was that it wasnt worth the effort as within 6 months a cheap Chinese copy would be on the market and his wouldnt sell. Talk about killing inovation and invention. Ciao
whats this about, ie what parts and why is it an upgrade? New cover with extra excentric adjuster, the shifter pawl, a banana shaped link the joins the two gear wheel pins as in a previous photo on this thread,new springs and a few other bits and pieces. Naturally doesnt come with the shifter shaft seal fitted to the cover or included. Will report on the outcome when I fit it up. My gearbox shift lever sometimes semi sticks for a fraction and you feel it tap the top of your boot after the shift has been done. I've already changed the shifter springs so this upgrade with additional adjustment and extra support for the selector gear pivot pins should shift better...I hope. Ciao
Just received my upgrade cover and shifter kit. Now I just need the time to install it. Ciao
So it went from .015mm which is way to tight to 3.0mm,is that right? Any valve that picks up nearly 3mm of clearance in 1000klms has obviously got major issues most likely a wiped out lifter and cam lobe. Why on earth would you even bother to adjust it. it needs the head pulled off and the lifters inspected for damage. Ciao
Preemptive Shift Return Spring and Pawl Arm Replacement
Lucky Phil replied to sp838's topic in Technical Topics
That's not a flange, it's a washer. Aha. Well I will try again! I thought it looked like a washer too, but it wouldn't come off... I will coax it off and see if I have a thin walled socket to fit. Thanks! Because the washer is thing the dome nut will have crushed it a little and it will have deformed into the threads. You'll need to grab the OD with some pliers and screw it off. Ciao- 48 replies
- false neutrals
- gearbox
(and 2 more)
Tagged with:
I have 2 low mileage bevel boxes and both have play in the front bearing. adjusting the ring nut didnt have any impact on the play. Have used both of them and it doesnt seem to be an issue but when I rebuild the spare if a new bearing doesnt remove the play I will attempt to shim it out with some home made shims if possible. To check whether the play is in the small internal needle bearing or the outer needle/ball hybrid just grip the input shaft and apply a longitudinal rotational force to it to load up the inner bearing then at the same time try to move the shaft up and down vertically. If you can still feel play at the end you are gripping then the play is in the outer bearing,if not its the inner.Both mine are in the outer bearing and from memory I calculated it at around 0.0015" radial which I can live with. I'd rather it be less but it is what it is. Ciao
You are going to be a very unhappy Guzzi owner if you think a leaking fork seal is a "big problem" believe me. Try using a seal mate before you pull the fork apart, it may have just rolled the seal during transport. Ciao
I bought mine fromMG cycles about 3 years ago Ciao
Is this the crossover without the support bracket? If so i'd steer away. Ciao
