ANSWERED 2003 V11 Sport Naked - serial number one?
Lucky Phil replied to chamberlin's topic in 24/7 V11
Yep I see now. Dont remember this arrangement on any of the Ohlins forks I have previously had, and there's been a few. Ciao -
That picture is for the marzocchi forks I think you will find. Your photo seems to be the spacer setup for the Ohlins ( I went and checked the shop manual) I now see the Ohlins appear to have the axle spacer slide into the inner race on one side and abut the inner race on the other. Normal config is for the inner spacer to abut the inner race on both sides as per the std Marzocchi forks. Ciao. Ammend, oh I see the inset with the Ohlins spacer and bearing config. -
Maybe its just objecting to being taken to England. can be a bit depressing there some times. Try a trip to sunny Italy, or even Australia. Ciao Just enjoying a real ale in the English sunshine. How's your pissy lager in the rain Phil ?? Ha, Warm Ale no doubt. Me I'm more of a Merlot/Cab Sav man myself. Then again I suppose you need something akin to Warm mud to kill the taste of the typical English cuisine. Ciao
Yes the Wilbers are bespoke also. You tell them your weight, whether or not you intend to carry a pillion, the type of riding you do and of course the model of bike and they build you a shock sprung and valved to suit. A remote spring pre load adjuster is optional but the shock length is set as you can only go about 10mm longer on the V11 shock or you will run into front uni joint clearance issues with the swingarm tunnel. The Wilbers also have high and low speed compression adjustability where the std Ohlins are low speed only. Some are fixated with the shiny gold shocks though. In my opinion the std Ohlins is not much better in quality or performance thatn you average Japanese bike shock. Thats why I upgraded my 1198s std Ohlins with the FGRT 803 forks and TTX rear shock.The std Ohlins are fairly average. Ciao
It won't be cable operated remote preload adjustment it will be hydraulic.Ciao Still learning something here every day. I suppose I must have known that at one time and it slipped with the rest of my mind. Plus, I removed the pannier to have a look and found the adjuster had completely backed off. Turned it back in and time to go for a ride! Thanks, Phil! (Corrected my post). DSCN1272.JPG It's just about having the right info out there docc Ciao
The cam and lifter have failed and the greatly increased valve clearance thus created has hammered the pushrod into what you now have. Ciao
Not that unusual really, its just porosity. I have seen it many times over the years mainly on Ducati crankcases but a friend also had porosity on the crankcase around the r/h cylinder base gasket area on his Mk4 lemans. My V11 also had a porous r/h cylinder head from the drain galleries which the previous owner had repaired with sleeves. Every pair of Ducati Corse crankcases I purchased new I would inspect for porosity before i acceped as probably 40% had issues of one form or another. BTW Locktite "wick in" would be the way to go in my opinion or if its a cleanish defined hole then what you have mentioned of Araldite works well. Ciao
I run a full spec Wilbers, preload adjustable, rebound, high and low speed compression. slightly longer than stock and raises the rear about 10mm. I have experience with Ohlins and Penske, primarily on Ducatis but also Triumph inc their road and track forks and TTx rear shocks and the Wilbers quality seems to be on par with them and the unit works very well. Ciao
The Ohlins forks you have bought AREN'T Radial caliper forks so your original calipers will be ok. As an aside, I dont like to reserviors you have fitted for 2 reasons, the mounting system looks so complicated it will probably give you issues eventually, and it just lacks elegance. Secondly powder coating will eventually start to blister and peel off due to sweating from the reservior cap seal. Even the stock ones do this eventually. Anodised units are the only way to go IMHO. Good thread though, lots of useful info:) Ciao -
Yes Dan Kyle is the man when it comes to Ohlins, supply and maintenance. Dont even think about going anywhere else. Ciao -
I guess you're horrified then by an electric fuel pump mounted inside the tank submerged in fuel Ciao
Scotchbright wont touch a Nikasil cylinder. Take them to your nearest engine reco place and get them to run a "flexhone" through them. Its like a bottle brush with stones on the ends and is commonly used after the final hone to finish cylinders. Wont remove any material to speak of and will give a nice finish for new rings. Will do that while you wait, takes all of 5 min. Make sure you clean the bores with warm soapy water and a brush after they are done then let them dry and wipe some engine oil into the cylinders with your hand then wipe it all out with a paper towel. Lube the gudgeon pin and rod fit the pistons and start it up. Rods straightness? why would they be bent? Cant see the reason for that.
How much oil was in the airbox sp? how many CC's ciao
Well sp838, I would be interested in a Galfer rear rotor if you can get me one. I cant find anyone selling them and they dont appear in their latest catalog. I just want one because they look a lot cooler than the dinner plate currently fitted. Ciao
I fitted an adjustable aftermarket one whos brand escapes me at the moment but it doesnt have the rubber isolators just rose joints on each end. It transmits noticeable but not really annoying level of bevel box gear rattle and driveshaft slop vibration through the footpeg on a neutral throttle. The l/h footpeg suprisingly. Ciao
Your kidding me right? have you ever lifted the rear wheel of a V11? I was in shock at the massive weight of the rear wheel of a std V11 the first time I removed one as i'm used to dealing with real sports bike wheels such as those on my 1198 Ducati and GSXR1000 Suzuki track bike. It was there and then that I decide that excellent handling was never going to be achievable with the V11 as on top off all that wheel lard there was still the weight of a bevel box and 1/2 of a reaction rod and drive shaft to consider. So a 3mmx 6mmx 230 mm ring of disk rotor material missing is but a drop in the bucket of lard that is the std rear end and it wont make a scap of difference in the real world. BTW the first thing I did when I felt how ridiculous the weight of the rear wheel/drive assy was on a Guzzi was to go and buy a decent high quality rear shock purly out of sympathy for the poor old std Sachs unit. The rear shock on a V11 has a man sized job to do thats for sure. Ciao
Why are people so obsessed with accurate idle speed? Who cares if the tacho says 1000 when its actually 750? Unless there is something dramatically wrong with the engine like low compression or an overly rich or week mixture then who cares if its idling at 1000 or 1200 as long as its not ridiculously out of the ball park it doesnt matter. I set up all my vehicles to idle where the engine seems happiest and most stable and ere on the high side. I can tell if its to high by the way it sounds and if it needs to be that high to be stable and reliable then there is an issue and I investigate. So my 1198 Ducati idles at 1400 rpm because thats where its happy. I could probably set it lower but why bother? My V11 i havent a clue, but its happy enough where its at and doesnt cause any riding issues and doesnt stall or overheat. Kind or reminds me of old guys obsession with how low a speed an engine will pull top gear or how steep a hill it will pull up in top. Ciao
I have several spare tanks and have tried the non chin pad on my 2000 green V11 which has the chin pad version as standard. I intend to fit the later tank when I get a chance as I think the external pump version has very messy feed hose arrangement. Any way the later tank will fit you just need to elongate the rear mount point to allow the slip nut to line up with the later tank. There isnt much in it, I measured the mount point dimensions of both types and there was a 3 mm difference. I believe the later one was longer from memory but it could also be just a natural variation in the manufacture of the tanks. Ciao
Guzzi cafe racer stop motion
Lucky Phil replied to John in Leeds's topic in Special place for banter and conversation
Looks like the venu is the Nurburg Ring. Ciao -
This statement and owning 10 MG's somehow seem at odds to me Ciao I am always at odds to that statement and I have only 4 Guzzi's ..... 4 Ducati's, a Cagiva, a Laverda 750 SFC, a BMW R90 (in parts), a BSA Sloper (in parts), 2 Puchs, a Honda mini-bike and a KZ 750B twin vintage racer project. I am at odds with a lot of things ...... Jim I thought I had a sickness:) Are any of these residing in your lounge room? like 2 of mine. Just thought I'd up the anti a little in the " no hope for" stakes. Ciao
I may be missing something here but from the description this isnt a dry sump setup. I would imagine the aluminium box to which you refer is a breather box.If there is oil on the end of a dipstick in the engine sump its still the standard wet set up. Draining the oil cooler is counter productive and just introduces air into the system on oil changes. The small amount left in the cooler is of no consequence and would be less than the total leftover oil that hides in the engine and doesnt drain during a normal oil change. Ciao
Hey Jim whos that riding the Magni in the Hailwood leathers? Ciao
