I rode over and met some guys for lunch today. Beautiful weather. As I headed off to come back home the bike sputtered and then died. I checked and there was gas. I restarted it and it was mostly uneventful on the way home. The oil pressure light came on for a second but then immediately went out around a corner.
I will admit I treat this thing like a Honda. Put gas in it and ride. There's probably a maintenance list that I'm completely ignoring. That might be catching up to me...
I should probably change the oil (not because of age but miles). Or at least check to see if it has oil.
I suppose my biggest fear is the original fuel pump will fail at some point. At least I think that's my biggest fear.
  • Haha 1
Posted (edited)
36 minutes ago, swooshdave said:
 the bike sputtered and then died...there was gas. I restarted it and it was mostly uneventful on the way home.
24 minutes ago, gstallons said:
... things to check !
Firstly, and easiest to check: the switch on the side-stand, the switch on the clutch, the kill-switch. All those "safety features" that will stop the motor if they have a fault.
Check them and make sure there is nothing dodgy, and take it from there.
Oh, and have a look inside the ignition switch.
After that, the relays, primarily those involved in the safety features.
But as @gstallons already wrote, there is a whole list of things it could have been. Maybe even "only" a bit of water in the fuel tank. :huh2:
Edited by audiomick
Would the side stand cause it to sputter and then die? Or just die immediately? I didn't touch the side stand when I restarted it. I did touch the side stand switch wiring recent to clean up the routing.
Relays were addressed when I got the bike.
It sputtered like it was out of gas which made me think fuel pump since it had gas. But my experience with fuel pumps is they just keel over (although I've had some that you could tap with a hammer to get them to start back up).
oil could be bad news.
Once happened to me with fuel starvation.   I was riding in hot weather.  Going for fill up but the pump was broken.   Hit that starter to go to another pump, impatient and didn't let the pump prime.  No start.  I tried several time and no go.  Pushed bike to another pump, filled the tank, and finally started.
IDK what brand relays you have but I would consider replacing them with quality Omron relays.
 The oil light situation: tomorrow first thing , check your oil level. If it is good , you will want to consider an oil / filter change. use a premium filter and good oil. If you feel confident about your skill level , install a Roper plate. a very important part. That oil light doesn't accidentally come on !
 AFA the fuel pump goes , they are usually good or bad...no in between. The only other problem I have seen is the fuel will start leaking from the electrical terminals. If at all possible use an OEM pump. It is the correct dimension such as diameter , length, everything. Unless someone has an aftermarket part # that will fit perfectly ?
