skibum69 Posted November 3 Posted November 3 Can someone take a photo and show me where the regulator/rectifier and alternator are on the V11 Sport Naked? Thanks
docc Posted November 3 Posted November 3 Alternator is under the round cover on the front of the motor. (Yours is likely silver and not so beat up as mine looks . . . ): Looks like this under the cover (potential wire attachment failure circled): Regulator is the finned, rectangular silver box "usually" mounted below the oil cooler between the horns: 1
Pressureangle Posted November 3 Posted November 3 Happens mine is on the bench waiting for new regulator to come. First is assembly, bracket horns regulator Second is bracket placement on frame. Hard to see behind mounted oil cooler. 2
gstallons Posted Thursday at 12:57 PM Posted Thursday at 12:57 PM On 11/3/2025 at 8:08 AM, skibum69 said: Can someone take a photo and show me where the regulator/rectifier and alternator are on the V11 Sport Naked? Thanks Is this for future reference ? 1
gstallons Posted Thursday at 12:59 PM Posted Thursday at 12:59 PM Just now, gstallons said: Is this for future reference ? The Moto Guzzi charging system consists of two states : Havin' trouble or fixin' to have trouble ! 1 2
audiomick Posted Friday at 02:24 AM Posted Friday at 02:24 AM (edited) 4 hours ago, Lucky Phil said: Mines mounted here. Quite likely a good place to put it, but it should be mentioned that one or two things on your bike aren't quite original. Edited Friday at 02:24 AM by audiomick 2
skibum69 Posted Saturday at 12:35 PM Author Posted Saturday at 12:35 PM (edited) I think I have a rectifier problem as it didn't seem t be charging last ride. I was just going to do a check in it according to the manual. If that's what it looks like it might be under the seat. Edited Saturday at 12:36 PM by skibum69 1
docc Posted Saturday at 02:48 PM Posted Saturday at 02:48 PM 2 hours ago, skibum69 said: I think I have a rectifier problem as it didn't seem t be charging last ride. I was just going to do a check in it according to the manual. If that's what it looks like it might be under the seat. As so often, first question is what relays are under the seat now? 1
skibum69 Posted 18 hours ago Author Posted 18 hours ago So according to docc it's not this one? This looks like a row of relays etc. 1
Tomchri Posted 18 hours ago Posted 18 hours ago It is. Hard to see what they are. 5-6 new ones probably a good idea. Clean everything, and make sure the relays sit tight. Some Caig Deoxit in there to. Think I woud relocate seat release wire to. Cheers Tom. 2
audiomick Posted 18 hours ago Posted 18 hours ago 34 minutes ago, skibum69 said: So according to docc it's not this one? is looks lik That's the ECU (Engine Control Unit), if that was the question. 1
PJPR01 Posted 18 hours ago Posted 18 hours ago On 11/6/2025 at 8:24 PM, audiomick said: Quite likely a good place to put it, but it should be mentioned that one or two things on your bike aren't quite original. Classic understatement there...well played! 1 1
docc Posted 18 hours ago Posted 18 hours ago 11 minutes ago, Tomchri said: It is. Hard to see what they are. 5-6 new ones probably a good idea. Clean everything, and make sure the relays sit tight. Some Caig Deoxit in there to. Think I would relocate seat release wire too. Cheers Tom. Good eye. @Tomchri! YES! @skibum69, groom that seat release cable back behind the relays and secure it with zip-tie! That is a TERRIBLE location for the cable wedged between the ECU relay and the Fuel/Ignition relay! 1 1
