- Past hour
12v/1.25 Amp
- Today
good suggestion, I will pour some Evan Williams and make some changes
SierraTango replied to fastaussie's topic in 24/7 V11
I apologize if I was unclear in my reply. I was suggesting that the OP take the closeup picture of the valve cover in post #1 to a experienced powder coating shop to see how close they could match it. I was not suggesting he take the picture of my bike to do so. I live in a smallish town and there are two excellent shops that do this type of work close by. I don't know why you found this funny? Please explain. -
Nicely simplified schematic. Just a note, that the red/black output from "Headlight" Relay (#2) does supply the brake light (also horns), but not the entire left switch cluster (i.e.: not the turn signals). Perhaps Fuse #5 (F5) should be indicated ahead of the Starter Relay. Turn signals are Fuse #7 (F7)
