This stream auto-updates
  1. Past hour
  2. Sorry , i didn't look at your location.
  3. Today
  4. That makes sense, the original ducati one is still available however it's over £200, I have looked on the Internet and they are selling from £25 upwards so my first thought would they be any good, its a 23 year old bike , so as you say over the years aftermarket parts would have become more available. Thanks for taking the time for your response, Dell
  5. Yesterday
  6. You find now with older machinery that is now supported by the aftermarket because the OEM is no longer available that you can't judge the quality by the retail price. A $200 dollar part you buy in your home country or the western market is still the same $20 item that is made in China for example. The often massive price difference is simply down to retail margins and sales volumes. The ignition pickup is an example. When I went looking for them for the Daytona engine 5 or 6 years ago the commonly available aftermarket ones varied in retail price enormously but were all the same Chinese manufacture. The difference between the direct cost from China and what the retailers were selling them for was massive. So from memory the aftermarket wanted 80 or 90 dollars for them and I bought direct from the Chinese manufacturer for $10 each. I bought 2 and the Chinese one fitted not only looked identical to the OEM original but has worked fine ever since. Things change. Why pay a hefty mark up for the same item from the same manufacturer.
  7. I'm in South Jersey near Philly.
  8. Anyone around in these parts? I'm in Sussex County, NJ.
  9. Cheers Pete, the original one is over £200, obviously I don't want to pay that amount, on the other hand I don't want to buy a cheap one and have problems with it. Dell
  10. The reg/recs are a very common fitment. You should be able to pick one up for £40 or less.
  11. I'll check it out Cheers Dell
  12. Have you tried Gutsibits in Huddersfield? https://www.gutsibits.co.uk/
  13. Cheers, I live in Wales in the UK, I should be able to source one a bit closer to home, thanks for replying, much appreciated Dell
  14. IDK if any other vendors sell one or not . Euro Motoelectrics in Denver sells electrical parts but IDK what brand they sell. I haven't had to buy one and IDK what is the best source.
  15. Thanks, Not quite yet, I need to buy a new rectifier, need to know has anyone used a differnt one from the ducati one. Cheers Dell
  16. good. I am glad you got it running !
  17. Found out the problem, rectifier was fried, its a ducati one, energia 343637, as these are expensive has anyone used a cheaper one that works well cheers Dell
  18. Thanks guys for the information Dell 👍
  19. Last week
  20. I'm on the Craigslist Airhead finds thread on ADV. That led to me finding an R100 RS close to home for a reasonable cost. For now one Goose will do me.
  21. I've been doing glucosamine with MSM for over 20 years. I recently went to a knee doc for mild joint pain and he said it was bone on bone and I needed a replacement. Take from that what you will, but I'm a believer.
  22. I thought the same thing, narrow engagement point on my '07 Norge, but bleeding the clutch yearly has kept it nice and crisp even as the next ride takes me over 50,000 Miles!
  23. The difference between the red frame bike charging systems and the black frame charging systems. To SamP and all others. The charging system wiring on the red frame bikes has the red/black wire going from the battery (green/black wire) to the F5 , then (blue) to the start relay to the headlight relay and then to the V regulator. ) The wiring on the black frame bikes goes from the battery to the (red/black) headlight relay and then to the V regulator. This looks like the only difference in the wiring diagrams of the charge circuit. The red/black wire goes to the batter through F3. The blue wire goes to the GEN light in the instrument cluster. The two red wires either join ant the connector of the V regulator or join at F3 in the fuse panel. The last two (yellow) go directly to the stator. Wire colors are a suggestion not an edict ! Trivia . The rotor is the rotating field and this is why it is called the rotor. The stator is stationary and this is why it has the name stator.
  24. SamP , have you done anymore about your alternator charging problem ? It has been a couple of days since I have been on and just checking .
  25. That would be this, I reckon. This "when scying TB" was probably supposed to have been "when synching the throttle bodies", I guess. To the first question: whether the engine is warm or not has absolutely no effect on the TPS Voltage. What is really important, as detailed in the thread linked above, is that there is nothing interfering with the throttle body closing completely. Connecting rod disconnected, high idle mechanism disconnected, throttle stop screw all the way out. All that. What makes it difficult to land exactly on the 157 mV is that the business moves a bit when you tighten up the screws. A couple of attempts will show in which direction and how much (approximately) it will move, allowing a better guess at what it should be before tightening. Also, within 2 or 3 mV is close enough, actually. When synching: the bleed screws are, more or less, only relevant at and just off idle. Based on the procedure outline from page 572 onwards in this workshop manual https://guzzitek.org/gb/ma_us_uk/1100/V11_1999-2003_Atelier(Compil-GB-D-NL).pdf The procedure there is for using the Guzzi diagnosis tool. We're not, so ignore the bit about 3.8°. Disconnect everything from the throttle bodies, and measure the Voltage with the multimeter. Re-connect all the linkages. Close the bleed screws all the way. Using the tool of your choice (vacuum gauges, or whatever) balance the throttle bodies at about 3,000 r.p.m. . Use the bleed screws and said tool of your choice to set the idle speed and balance the throttle bodies at idle. That's a summary. Read the thread in the link above for the full story.
  26. @thumper, you did tell the new owner about the forum, I hope?
  27. I don't know if the clutch cylinder is the same internally as the V11, but I've had the internal spring break into pieces a couple times. There was excessive lever play and the engagement range was affected ... The last time I found it like this: First time, along with rebuild kit:
  28. It’s exactly the same clutch that is in the V11 and all other big blocks since the end of the Cretaceous. If he is finding that the clutch is only starting to lift at the very end of its travel the most likely cause is that the plunger on the lever, (NOT the span wheel.) is maladjusted. Also all the CARC bikes, (And V11’s.) are murder on their clutch fluid. If it hasn’t been changed regularly the bore of the master cylinder may be damaged limiting the efficacy of the piston’s stroke.
  1. Load more activity
