p6x
    101
Everything posted by p6x
  1. After fixing my broken tag support, I decided to make up for the lost trip to South Padre Island by going to Gladewater Tx. Stops #9, 16, 17, 18 setting me 15/50 a return trip of 440.5 miles (709 km). As many places in the USA, Texas is under extreme heat, compounded by the elevated humidity in the State. Because of these conditions, we experience torrential, tropical storm likes; I went through one yesterday on the 259. The temperature during the ride was 104 degF (40 degC). When I got back at 7:00 pm 96 degF (35.5 degC). The sudden tropical storm I went through concerned me. I saw the lightning from afar, but did not hear any thunder; I assumed I was safe. The storm hit between Kilgore and Henderson while in the forest. Visibility null. I got behind a truck, and stayed there. I did not want to stop. I got completely soaked, but I was dry when I got home, excepted for the socks and the seat side of my riding jeans. The Michelin Road 5 did pretty well under those diluvian conditions. No hydroplaning and I maintained confidence. But I cannot ignore that riding in such conditions is unsafe, and should be avoided. There was no place for me to stop, and my tail light was probably invisible given the curtain of water falling. This is why I stayed close to the truck in front of me. His lights could be seen better. I kept at a safe distance although we were going about 45/50 mph. The rain did not subside until Nacogdoches. My hands were completely black from the gloves. Difficult to remove too.... Nevertheless, I really enjoyed the outing which basically served no other purpose but to ride the Guzzi. The V11 did pretty well in the heat, considering how much of it, and did not mind the water either. The only issue is the oil seepage which seemed to have resumed. I don't want to immobilize the Le Mans any longer. I will add oil as required. This is the temperature at my first stop in Kilgore Tx. The #8 stop in Kilgore Tx. Under the blistering heat! The former drilling derricks close to Kilgore downtown. Texas has plenty of them. Initially, the derrick would stay all through the life of the well, and would be used for the required workovers. Nowadays, if you own a well, you call a drilling or workover company for the intervention. Note that those structures were only good for shallow wells, as it was back the beginning of the black gold. The oil was a few hundreds feet under the surface. Today, the easy oil has been already found, and you need a better structure to drill and work deeper. The 16, 17, 18 stops in Gladewater Tx. Almost identical stop for stop to last year's. Not as much fun when repeating stops in places you have already been. At least, I did not need to look to find the locations... Here's the trip details, beginning on 10:38 and ending on 19:12. There were only two major stops to refuel. The reported mileage is not accurate since the App computes the distances arbitrarily, not according to the route used. But it is good enough for my own personal tracking. Fuel consumption was always above 40 mpg, which is basically what I expect to achieve on the road, never exceeding 5000 rpm. If I break that barrier, then it deeps pretty quickly. Here's the temperature taken upon arrival at 19:12 yesterday. Now I need to clean the bike and think about my next venture. I am running out of day ride stops though. The South Padre Island trip is postponed for the time being.
  2. My most pressing objective is to be able to ride. I am hopeful that with that welded reinforcement beam, I have some miles ahead of the same problem happening again. Since I dropped the bike, the maimed mud guard was evidence the cracks may have also been incident induced. One small step for me, many more miles for the Le Mans before the next issue....
  3. German GP.... another "see you later" from Fabio Quartararo; another DNF from Bagnaia, another 2nd place for Zarco... I would vote Zarco to replace Miller at Ducati factory's. This is the guy that would exerts the least pressure on Francesco's Bagnaia. He is pretty solid if not sensational. It seems to me something went wrong with Bagnaia, the way he lost the rear was strange, even Bagnaia seemed surprised. Viñales' Aprilia's issue was a shame... Well, it certainly looks like Fabio Quartararo is en route for another championship.
  4. I have so many questions I'd wish to ask him! one day, one day....
  5. How easy/difficult is it to get to those four lamps in the dashboard? If you do not leave an incandescent lamp for the low fuel light, do you need to install a resistor to keep the system working as intended? besides, there is some water trapped behind the orange reflector. I need to get to it, drain and seal.
  6. @docc I still have a question: is the front light of the V11 sport and V11 Le Mans the same in terms of reflector and internal space? The lamps are the same, so I suppose they should be identical, but I would rather confirm.
  7. I reply to my own query:
  8. I noticed the parking light is always on when I turn on the ignition, coupled with low beam. I would have thought this light would only be useful as a "parking light", so lighting on its own. My 911 has a parking light position, if you are parked at night you can leave them on so the car stands out. Maybe Guzzi has something similar?
  9. Here's the support bracket installed again. I replaced the zip ties by two 8mm CHC screws with lock nuts. I replaced the two cruciform fasteners with two 6mm hexagonal head stainless steel screws with conventional nuts. I need slightly longer screws, those are 15mm long; I need 20mm and lock nuts. I had to replace the 1157 Bulb; only the brake light worked. I saw a large selection of led lights to replace the incandescent ones, I did not know which to pick (I read on a forum that some of those are really poor quality). I will check if we already have a topic about this.
  10. One aspect of the oil which he has not touched upon is the infamous additives. They were not the point of focus of this test. Noticed that a many of the top performers in the "extreme protection" list are oiled aimed at V Twin engines.
  11. I looked at the plots more than the narrative.
  12. I found a better way to get the mudguard attached to the assembly. But I am going to need different fasteners. Another trip to the nut place then.... I am going to be able to use longer 6mm screws instead of that zip tie. The difficult part will be to reconnect the wires while holding the tail light & turn indicators piece. There is not much play in the wiring. Obviously, after everything is installed and tightened up, that will be the time when I find out that the rear left and right turn indicators are inverted....
  13. How do we differentiate a V11 engine with a Norton Commando one? The article is interesting in presenting tests and results and providing the data. I don't think we can infer what is good to a V11 from what's good for a Norton Commando though.
  14. The welding shop called me at 1:30. They thought it was more important to do my repair rather than work on that BOP. Nice! Here it is with a reinforcement before painting. If it breaks again, it will not be at the same place. Tomorrow I will put everything back together and get ready to go. The heat is indescribable. I went to the welding shop with the 911 opened, 104 degF on the thermometer...
  15. I was lucky? young enough? to see him race on MV Agusta bikes. He is still attending all the events he gets invited to.
  16. @GuzziMoto I heard the same thing; honestly, I think he should maybe carry it at least one more year in Moto America, even if wins the title. I think Ducati can use the publicity here, although I read their most sold motorbike in the USA is the Multistrada V4. I have noticed that Moto America has so far not asked Petrucci to do the opening on YouTube as the other riders do: -" Hi, I am Jake Gagné, thank you for watching Moto America on YouTube; like and subscribe!"
  17. Thanks for all the suggestions and advice from all, and help from @KINDOY2. This morning I visited a welding shop who took the job. We agreed on how to do it. As usual I will post pictures once I get it back. The actual bracket will be reinforced in both axis by adding some beams. It should not brake again. With a bit of luck, I should get it by tomorrow. These guys are working on oilfield equipment for major companies, I looked silly with my little bracket.
  18. Well, I was lucky that it did not happen while I was traveling. I am going to do a bit of engineering on that support, to make sure it does not happen again.
  19. I agree with you. #7 has been shortened. The modification and the reduction of fasteners has properly made the support failure prone. Once I manage to find a welding shop I will check if we can add some support beams so I don't experience that same issue again. I am so bummed to be immobilized again. I was looking forward to that South Padre Island excursion. I also have to listen to people telling me I should purchase a bike that works...
  20. Just the plastic zip tie. I don't think the tail assembly is original. The entire assembly is supported by the bracket that broke. I did see some unused holes when I took it apart. I think I am missing item 7, number plate holder.
  21. The mud guard is broken too. The right side may have happened when I dropped the bike last year. The left side, I had never noticed it before.
  22. You can see the plate broke close to the welds on both sides. All the weight and the vibrations are concentrated there. You can see that when the plate is bolted on the chassis, you got that cantilever part holding the tail light and turn indicators, and it is only supported by what, 1.5 cm of steel.
