    1,188
  1. I'm having trouble finding a way to make some proper measurements, but there is *about* 10mm more space between my front subframe and the exhaust "header" pipe on the right than there is on the left, but when I project forward from the heads with a rigid beam and measure to the side of the forks there is 125mm +/- 1mm on both sides (engine looks centered to the forks). Factory drawings dimension the right pork chop mount (rear cross tube of the spine frame) 9 mm further out than the left, but I cannot find dimensions for the engine mounts. But, I can also slide more of my hand between the tank and valve cover on the right . . . So, I'm confused having always accepted that the driveline was offset right 12mm . . .
  2. Looking great! It would have taken me year to get all that done. I hope gstallons chimes in on the brake thing.
  3. Regarding cleaning brake components, I recall gstallons being absolutely adamant not to use petroleum products (ie: WD40), but only brake cleaning solvent and silicone based lubricants. Any time the calipers are off it is good to work the pistons in and out while cleaning with brake solvent until they all move evenly. The improved brake feel can be remarkable.
  4. docc
    More brochures
    V11 Sport Scura brochure archived in Fileshare.
  5. There is not so much of an "answer" to that good question , but more of a discussion . . . For starters, the V11 LeMans came in two generations: the "inaugural" 2002 and Gen II. So many incremental changes crept in along the way, and year-model changes overlap, while the dates are further blurred by worldwide distribution. In short, the Rosso (red) and Nero (black) Corsa were second generation (2003-2004) LeMans (full fairing) with special paint/graphics and upgraded (Öhlins) suspension. Certainly, some of the best of the breed!
  6. Those are the bridges of my (misguided) youth! Back in the day, The Authorities thought it a poignant deterrent to delinquency and dereliction to mount a speed sensor displaying a "If Lights are Flashing, You Are Speeding" message out on Clearwater Beach Causeway. The game became: how many palm trees away can you tromp it from a dead stop and still trip the warning. (The Cleveland powered Cougar could do it in two trees! We'll definitely be headed back into mid-Pinellas that direction. Everyone is welcome to come for any or all of the day. Nic and I are also planning a Friday foray along the "Nature Coast" (we always called it the Smuggler's Coast), from the Withlacootchee at Yankeetown up to Cedar Key and the mouth of the Suwanee. Anyone interested in exploring that series of dead-end roads - let me know and we'll expect you in Yankeetown (Inglis).
  7. http://www.ebay.com/itm/Guzzi-2000-V11-Lemans-Sport-Seat-/400901510777?hash=item5d57979679&vxp=mtr
  8. All the frame changes were starting 2002. I don't think the swingarm changed The Workshop Manuals and Parts Manuals are available online from Teo Lamers.
  9. Roy, I thought you were kind of a wire nut your-own-self!
  10. I'm getting 58mm/ 1 5/16" width of the caliper carrier where the axle passes through.
  11. Mike, I made a new topic in Technical Topics for best response.
  12. Don't feel bad about being tricked by a battery that shows perfect voltage then drops out when it's needed. In the meantime, you've done some fine fettling and that always adds up to a better bike!
  13. Which features, those?
  14. Scud, thanks for the theme song! If we count going both directions across the Sunshine Skyway, there's your seven bridges right there! As long as it doesn't become A Bridge Too Far . . .
  15. The test light idea is brilliant! (Even though a small multi-meter lives in my left pannier, & test light in the tool roll. By the air compressor and tire plug kit) . . .
  16. Nice work! I did manage to blow one of these fuses by letting my positive terminal get loose. It was nearly impossible to see the break at the roadside, so I changed to the type that lights an LED when blown. Hopefully, I won't be seeing that little light!
  17. The Universal Map Symbol for a bad idea for a left turn:
  18. Seems a hundred (US) dollars +/- for correct spring weights and fresh (well selected) fork oil go a long way . . . as long as the rear spring and pre-load is also set-up . . .
  19. For sure, the (byproducts of) ethanol in the fuel are not Nylon (polyamide) friendly, and there have been various attempts to seal the PA tanks. It seems to me (having used the typical 2-part epoxy for metal tanks) that the coating would have to be a bit flexible to accommodate the polyamide. No doubt, keeping your ethanol in glass seems the best solution. Store until ready for consumption!
  20. This is my, somewhat pathetic, approach to not getting the correct charger for the Odyssey PC545 : Odyssey PC545 Battery conditioning
  21. So many places for the Fun to Start!
