swooshdave Posted 10 hours ago Posted 10 hours ago I rode over and met some guys for lunch today. Beautiful weather. As I headed off to come back home the bike sputtered and then died. I checked and there was gas. I restarted it and it was mostly uneventful on the way home. The oil pressure light came on for a second but then immediately went out around a corner. I will admit I treat this thing like a Honda. Put gas in it and ride. There's probably a maintenance list that I'm completely ignoring. That might be catching up to me... I should probably change the oil (not because of age but miles). Or at least check to see if it has oil. I suppose my biggest fear is the original fuel pump will fail at some point. At least I think that's my biggest fear. 1
gstallons Posted 10 hours ago Posted 10 hours ago Red frame ? Whewwww. it could be ANYTHING . We will put on our thinking caps and come up with some suggestions and things to check ! 2
audiomick Posted 10 hours ago Posted 10 hours ago (edited) 36 minutes ago, swooshdave said: the bike sputtered and then died...there was gas. I restarted it and it was mostly uneventful on the way home. 24 minutes ago, gstallons said: ... things to check ! Firstly, and easiest to check: the switch on the side-stand, the switch on the clutch, the kill-switch. All those "safety features" that will stop the motor if they have a fault. Check them and make sure there is nothing dodgy, and take it from there. Oh, and have a look inside the ignition switch. After that, the relays, primarily those involved in the safety features. But as @gstallons already wrote, there is a whole list of things it could have been. Maybe even "only" a bit of water in the fuel tank. Edited 10 hours ago by audiomick 2
swooshdave Posted 8 hours ago Author Posted 8 hours ago 1 hour ago, audiomick said: Firstly, and easiest to check: the switch on the side-stand, the switch on the clutch, the kill-switch. All those "safety features" that will stop the motor if they have a fault. Check them and make sure there is nothing dodgy, and take it from there. Oh, and have a look inside the ignition switch. After that, the relays, primarily those involved in the safety features. But as @gstallons already wrote, there is a whole list of things it could have been. Maybe even "only" a bit of water in the fuel tank. Would the side stand cause it to sputter and then die? Or just die immediately? I didn't touch the side stand when I restarted it. I did touch the side stand switch wiring recent to clean up the routing. Relays were addressed when I got the bike. It sputtered like it was out of gas which made me think fuel pump since it had gas. But my experience with fuel pumps is they just keel over (although I've had some that you could tap with a hammer to get them to start back up).
footgoose Posted 7 hours ago Posted 7 hours ago my first thought is gas. either nasty or water. depending on the level of neglect, could just be condensation. (cuz where you live) If it's been awhile you may want to drain and flush the tank.
pete roper Posted 7 hours ago Posted 7 hours ago If the oil light came on briefly it’s bad news. It is likely low on oil. Does it have a sloppage sheet fitted? 1 1
LowRyter Posted 6 hours ago Posted 6 hours ago oil could be bad news. Once happened to me with fuel starvation. I was riding in hot weather. Going for fill up but the pump was broken. Hit that starter to go to another pump, impatient and didn't let the pump prime. No start. I tried several time and no go. Pushed bike to another pump, filled the tank, and finally started.
gstallons Posted 5 hours ago Posted 5 hours ago 5 hours ago, swooshdave said: I rode over and met some guys for lunch today. Beautiful weather. As I headed off to come back home the bike sputtered and then died. I checked and there was gas. I restarted it and it was mostly uneventful on the way home. The oil pressure light came on for a second but then immediately went out around a corner. I will admit I treat this thing like a Honda. Put gas in it and ride. There's probably a maintenance list that I'm completely ignoring. That might be catching up to me... I should probably change the oil (not because of age but miles). Or at least check to see if it has oil. I suppose my biggest fear is the original fuel pump will fail at some point. At least I think that's my biggest fear. IDK what brand relays you have but I would consider replacing them with quality Omron relays. The oil light situation: tomorrow first thing , check your oil level. If it is good , you will want to consider an oil / filter change. use a premium filter and good oil. If you feel confident about your skill level , install a Roper plate. a very important part. That oil light doesn't accidentally come on ! AFA the fuel pump goes , they are usually good or bad...no in between. The only other problem I have seen is the fuel will start leaking from the electrical terminals. If at all possible use an OEM pump. It is the correct dimension such as diameter , length, everything. Unless someone has an aftermarket part # that will fit perfectly ?
motortouring Posted 29 minutes ago Posted 29 minutes ago 7 hours ago, swooshdave said: Would the side stand cause it to sputter and then die? Or just die immediately? I didn't touch the side stand when I restarted it. I did touch the side stand switch wiring recent to clean up the routing. Relays were addressed when I got the bike. It sputtered like it was out of gas which made me think fuel pump since it had gas. But my experience with fuel pumps is they just keel over (although I've had some that you could tap with a hammer to get them to start back up). If you rerouted the wire of the side stand, you might check ifnit is not stuck and somewhat dismantled under the generator cover. Dont ask how I came up with this idea.
motortouring Posted 26 minutes ago Posted 26 minutes ago 7 hours ago, pete roper said: If the oil light came on briefly it’s bad news. It is likely low on oil. Does it have a sloppage sheet fitted? Could be, but it could also be a shortcut that illuminates the light shortly. I thought the info of the rerouted wire should need some attention.
