- Past hour
Thanks Phil...very good and educational explanation...I'll try experimenting at the next oil changes on the Norge/Griso/Scura with a viscosity spread of 30...if I can perceive any improvement in performance, "feeling" and / or mileage that would be a bonus.
- Today
12v/1.25 Amp
I think I have an extra set of frame plates and valve covers if you want to take them to a powder-coater or painter. I could sell them to you, or you could give me back your take-offs after you swap in the painted ones. We are only 100 miles apart.
