docc Posted August 7, 2017 Report Share Posted August 7, 2017 1) Buy beer, invite friends: (photo courtesy of Nick, 2016 South'n Spine Raid) Or, 2) Use The Goof-Proofed Tank-on Method: Helps if the tank is empty, and tighten a little at a time. 1 Quote Link to comment Share on other sites More sharing options...
footgoose Posted August 7, 2017 Report Share Posted August 7, 2017 awesome. yet another use for a ratchet strap. getting up there with duct tape for utility. Quote Link to comment Share on other sites More sharing options...
fotoguzzi Posted August 7, 2017 Report Share Posted August 7, 2017 that flaw is a disgrace to what could have been the greatest Guzzi ever. I really loved my V11 but probably never buy another one. Quote Link to comment Share on other sites More sharing options...
footgoose Posted August 7, 2017 Report Share Posted August 7, 2017 The real disgrace is the continued use of Acerbis nylon for fuel tanks. The USA must be the largest consumer of all the marques and models that use them, and they can't or won't figure out a way to accommodate alcohol. And why there's still alcohol in our gas this day and age is just silly. 1 Quote Link to comment Share on other sites More sharing options...
coreytrevor Posted August 7, 2017 Report Share Posted August 7, 2017 Mine is expanded somewhat too but I can still get the bolt in. The tank was coated inside when I got the bike so fingers crossed it doesn't get any worse. Seems like coating the tank before it grows much is the only prevention if you are stuck with ethanol fuel. Quote Link to comment Share on other sites More sharing options...
bbolesaz Posted August 7, 2017 Report Share Posted August 7, 2017 What do you coat it with? Slosh sealer? Quote Link to comment Share on other sites More sharing options...
LowRyter Posted August 7, 2017 Report Share Posted August 7, 2017 my tank can be removed and reinstalled without being toughly muscled. But the nose of the tank gets some rash due to full lock on the bars (a little more prone on the left side). Quote Link to comment Share on other sites More sharing options...
swooshdave Posted August 7, 2017 Report Share Posted August 7, 2017 my tank can be removed and reinstalled without being toughly muscled. But the nose of the tank gets some rash due to full lock on the bars (a little more prone on the left side). Mine too. Left side has a mark, right side no mark. We'll see if running non-ethanol helps. I try to whenever I can... afford it. Quote Link to comment Share on other sites More sharing options...
coreytrevor Posted August 7, 2017 Report Share Posted August 7, 2017 What do you coat it with? Slosh sealer? The Ducati people that have nylon tanks seem to like this stuff. http://www.caswellplating.com/epoxy-gas-tank-sealer.html Quote Link to comment Share on other sites More sharing options...
Chuck Posted August 8, 2017 Report Share Posted August 8, 2017 ^^^^ I did a tutorial on putting a Caswell liner in Rosie's tank on WG, but Photoblockit has the pix. If anyone wants, I could restore it. 1 Quote Link to comment Share on other sites More sharing options...
footgoose Posted August 10, 2017 Report Share Posted August 10, 2017 Never mind I won't bore you with how to do it I'm sure I read your description somewhere using leverage with a piece of wood?? That's how I do it!! My tank does not get all that large when it's off. The bolt hole is usually only about 5mm off. I do have to remove the Simon Cowl or it scrapes hard against it. Last winter the tank was off and dry for 4 months, and it had shrunk back somewhat. The winter before I built a jig to store it on as if it were still mounted on a bike. Not much difference with or without the jig. I think 5mm long is it's 'happy place'. We'll see when I put it back on after being off 6 weeks. Quote Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted August 11, 2017 Report Share Posted August 11, 2017 Getting the tank past the seat surround is the hardest part Step 1 remove the seat surround (6 screws, 2 small ones underneath) Step 2 take a short length of 2 x 4 (11 - 11-1/2") and a suitable lever, pryer, tire iron Step 3 place 2 x 4 against rear of tank (behind the bolt hole) Step 4 lever the tank forward using the frame tube behind the ECU as a fulcrum point. You may also need a screwdriver or something to line up the captive nut You may have to remove the ECU or battery to give more clearence Quote Link to comment Share on other sites More sharing options...
docc Posted August 11, 2017 Author Report Share Posted August 11, 2017 Step 1 remove the seat surround (6 screws) Step 2 take a short length of 2 x 4 and a suitable lever, pryer, tire iron Step 3 place 2 x 4 against rear of tank (behind the bolt hole) Step 4 lever the tank forward using the frame tube behind the ECU as a fulcrum point. You may also need a screwdriver or something to line up the captive nut I'm trying to figure out Step4, what to lever against. Seems my battery is on the way? Quote Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted August 11, 2017 Report Share Posted August 11, 2017 My Greeny has a frame tube behind the ECU, I moved the ECU out of the way also 1 Quote Link to comment Share on other sites More sharing options...
Scud Posted August 13, 2017 Report Share Posted August 13, 2017 I needed to do this again today. Here is how I got a little leverage from the battery tray, not the battery. Also, it is much easier to get the threads started if you partly or fully remove the metal sleeve from the rubber grommet. Once the threads are started, the big washer will force the metal sleeve back into the rubber. 1 Quote Link to comment Share on other sites More sharing options...
Join the conversation
