- Today
For those of us with no fb access, perhaps post a few specifics? Maybe "hot-link" and image . . .
If these are sealed roller (ball) , you can remove the dust cover and pack the bearing cavity w/grease and reinstall the dust cover .
Pretty sure I posted this before, but came up again with a significant price reduction. NY/NJ border. https://www.facebook.com/share/p/E9yTeV6ri3aL4fUG/?mibextid=kL3p88
The Beeline Moto II landed on my doorstep on Friday. Just been out on a familiar run and the Moto II is far more intuitive. The original Moto was a fine little gadget for assisting with navigation, just to confirm our decisions for a route we’d already researched. However the Moto II is a real leap forward. It shows deviations in the road layout, and has impending turn alerts in blue LED.
What [music] do you listen to? Share your favs
p6x replied to Admin Jaap's topic in Special place for banter and conversation
Only in Texas folks, or Y'all... I was 5... -
Specifically the swing arm bearings. Carc bikes did not receive proper lube from factory. It's a Stelvio, but all Carc bikes need it...per Mr. Roper.
Are you talking about greasing the u-joints and everything else with the axle shaft ?
After bleeding properly I checked the fluid levels by measuring distance down from top of tube. Both sides were only about 8mm low. So I guess the 600 ml I poured out when first opening them were close to spot on, because that's what I initially filled them with after putting in the new seals. I did add a dash to bring them up to spec, and forks are on the bike now. Next is to put on lift to remove swingarm and grease bearings. Then just a few more little things to do before John Day.
Aha. Mines spent a bit of time in the sun without any issues but is an 01 model. Just doesn't quite look right in polished silver to me.... Cheers
Dont think they are chromed
- Yesterday
I did my first (short) ride with the UPIII. There is a significant flow of air through the mesh, yes. It is better than the Bowtex which has known. The UPIII has a better slim fit but the air circulation is not making you feel a lot more comfortable than in the Marsee. I am guessing that if the place was not so humid, it may work better. But it is definitively an improvement from the Bowtex in terms of air flow. The Marsee is still relevant, though.
So, an early 1999-2000 production judging by the finned, steel exhaust header flanges. This run also suffered from the red stillettos fading to pink. Some P.O. likely stripped them to the bare alumin(i)m . . .
Gasoline. Yes the Germans had the burden of high octane fuel in insufficient quantities and quality. They also used aromatics to boost the octane that had a higher vapour point and resulted in sever fuel dilution which destroyed engine bearings. Big issue for them for a while. They were also short of Nickle for exhaust valves which led to them developing chrome plated exhaust valves. They were fighting with one hand tied behind their backs in engineering terms thankfully for us. It took the allies over a year to figure out the Nitrous oxide injection the German were using. They found the systems fitted in crashed German aircraft but they couldn't figure out the gas they were using. A lot of the German piston engine tech was lost after the war when the gas turbine took over and designers are now starting to use what they developed in WW2 in modern engine design such as Direct gasoline injection. Yes I've seen just about all of Gregs video's and he's very good although my Spitfire wing knowledge comes from another source Gregs backs up my readings on the subject. His car stuff is good as well. The English post war had a knack of burying the brilliance of the "non English" and exaggerating their own peoples contribution. The winners write the history as it were. Phil
Dunno why you'd chrome her chops or stilettos.... They look much better in Red!
True! Although the delivery was made by UPS, it took only 48 hours more or less. Texas is back to the temperatures we already experienced in 2023, unfortunately. I took a short ride yesterday to check my new helmet, with the Bowtex elite shirt which is AAA. the Knox is only AA. Right away, I could differentiate the armor between the two. The Knox' is a lot thicker, and heavier. The heat index is again in the triple.
Welcome back, @Drahchir! I moved the image of your lovely LeMans for all to see!
I did not. But I did read a lot about the differences between the German and English respective engines that equipped their respective planes, and how performance compared at various flight levels. The DB 605 was such a technological marvel of engineering; fuel injected when the Merlin had carburetors. One of the main drawback the pilots experienced was the low octane fuel Germany had to use, while the allies had access to better quality kerosene. Therefore, I knew about "Miss Shilling's orifice". I was more interested in the Messerschmidt Bf 109 engine, while ultimately my favorite was Kurt Tank's Fw 190 in terms of design. A very interesting man, that dispensed his art also in Argentina and in India.
