This stream auto-updates
  1. Past hour
  2. Seat is in like-new condition. It has a heater and wiring kit (never installed) and a backrest for the passenger, which was never used, because it didn't fit with the top case. I paid over $1,000 for the custom seat in March 2024. Traded the bike with the stock seat for a new Stelvio, which is the reason I am selling the Corbin. It was super comfortable and seemed a bit lower than the stock seat. Asking $500 plus shipping if required. I still have the original box and packing material from Corbin.
  3. Today
  4. Good. One time we had to install some sensors on the Bell housing and set the air gap to XXX . We got the flywheel tooth to the center of the bore , and figured the air gap with the revolution of the sensor threads and bottomed the sensor against the tooth and backed it out accordingly to get the proper air gap.
  5. Yes. The safety margin is that, as I wrote, the bolt wont fit between two teeth, and I also ground off the end of the bolt so it is dead flat, no taper in to the thread. So even if just the very edge of the bolt is on top of a tooth, it should still take a good measurement. But that is just the safety margin. I made sure that a tooth was in the middle, and am quite sure my bolt was hitting it squarely.
  6. I think we are talking about the same thing......You are making sure one tooth is in the center of the bore where the sensor goes ?
  7. Yes, hot water should work as well, and leave no trace.
  8. Yesterday
  9. I didn't worry about TDC, but did have a look at where the teeth on the wheel were, i.e. a tooth there where the bolt in the tool was landing. On top of that, I had a good look at whether the M5 bolt that I was using in "my" tool to measure the distance would fit in between two teeth on the the wheel. It wont. I took a measurement, and went in with the vernier caliper to check plausibility. Then put the bike in 2nd gear and bumped the motor a bit. Took another measurement, and came up with the same result. I'm pretty sure that the measurement is solid.
  10. I assume you got one tooth at TDC in relation to the centerline of the sensor ?
  11. Yeah, I think it has a bit of a bulge. I have a replacement, so I will most likely just replace it. Might test it, but the power in the garage is photovoltaic, and doesn't have enough bumps (German word...) to power the hot air blower. Maybe I'll have a look at it at home in the kitchen when the girlfriend is at work.
  12. It's hard to see clearly, but it looks like your sensor has a little bit of bulge in the center. When mine failed, it was so bulged there that it was hard to pry out. Consider. I bench tested mine simply by checking resistance while cold, heating it with a heat gun (shop hair dryer) and checking with an IR heat gun. When the sensor got to about 170*F, it opened. Measured ok again when cool a couple times.
  13. audiomick
    Neglect
    Indeed. @swooshdave , please keep us posted on what you find.
  14. Tom, that is very pretty, but I don't have the machines to make something like that. Fortunately, one of the blokes that shares the garage with me bought a drill press a while back. With that, I can drill holes in bits of metal that go really straight through. The rest of it was done with hand tools. I also liked the idea of a tool that can be screwed on to where the sensor sits. A bit of a fiddle to get it on and off, but security that it is really sitting where the measurement is to be made. Whatever, I'm happy with the result. Others have "better" tools for the job, but mine does it well too.
  15. And a square head edt, easy and fast to use. Cheers Tom. Sent fra min SM-S906B via Tapatalk
  16. Weegie
    Neglect
    Just wondering if the oil level was really low and you cranked into a turn, you uncovered or partially uncovered the pump suction, leading to a momentary loss of oil pressure. If that was the case then in all probability it would recover pressure once upright or close to upright, explaining the event. If the oil was really low then the Roper Plate would probably do little to prevent this Of course I'd go through the preventitive actions already mentioned by others and me, just to entirely rule out other causes. Good Luck with the checks, be interesting to know what you find. John
  17. A brief excurse back to the V11: today I made a tool. On the way home it occurred to me that I now know what I wanted to measure, and may well never need the tool again. Still, making it and seeing that the idea worked was satisfying. Anyway, this is it: Using that, and cross-checking for plausibility with the vernier caliper, which can do depth measurements, I was able to establish that the old timing sensor is more or less the same length as the new one, i.e. 30 mm. The distance from the seating surface to the toothed wheel is 29 mm, and the sensor had two 1mm shims fitted. So the gap was 1mm (verified by holding the sensor against the tool and sticking a feeler gauge in between). That is, according to what someone further up quoted from the good book, within spec. Nevertheless, I'll try and get a 0.7mm shim to get it down to around 0.7mm. PS: I was a little disappointed. I had kind of hoped that the sensort would be deformed and the gap far too much. That would have offered an explanation (maybe) for the poor running.
  18. docc
    Neglect
    That sounds like classic V11 "heat soak" made worse by the ECU always starting up and running a rich map for the first 4,000+ rpm. This effect is exacerbated when the plugs/valve adjustment/state of tune has aged out from the last service interval . . .
  19. swooshdave
    Neglect
    Sweet talking in French is outside my wheelhouse.
  20. Well maybe best to give it some oil and a tender hug on the tank and say some kind words. That always worked for my Peugeot Diesel.
  21. swooshdave
    Neglect
    Sorry, yes, let me attempt to clarify. I went to lunch and then dropped by my friends house. I shut the bike off for 5-10 mins. Started the bike up to leave. Got about a block or so away and it sputtered. Bike was definitely warm. Pulled over and shut the bike off. Restarted the bike and it ran fine. One the way home (it's about a 15 minute ride in total) I went around a corner and caught the oil light on for a second. It went out and I noted it. Did not reappear. Have not checked oil level yet. Have not ridden it since. Mostly the post is about how people really shouldn't be like me and neglect the maintenance. Ironically I grabbed the Norton later for another ride and it had a similar sputter. Turned out to be a loose spark plug wire. It wasn't my day. Which is too bad as the weather was perfect.
  22. The core tenets of humor are ignorance, misunderstanding, and plausible deniability.
  23. Weegie
    Neglect
    Hi Dave Not sure of the sequence of events, the bike stuttered and died after sitting some time, after you had lunch, so it was cold, or slightly warm but not hot? When did the low pressure light illuminate after starting? Did it stay on after you applied some throttle/revs then go out and only flickered on for a second or two? Just my opinion, the flicker of the light could be nothing, the switch/connections needing attention or genuine low pressure and investigation into the mechanicals. Many others have gone into the probable causes. I'd first check oil level, then get a gauge onto it, remove the plugs (to lessen the strain on the bearings and increase crank speed) and crank it over. If it's cold the oil pressure should register quickly, within a few seconds and spin up to at least 40, I usually see 60 on the Sporti (more or less same bottom end) I'd be concerend about engine mechanical integrity first, sputtering and faulty pressure swtich/electrics would concern me less, although obviously needing to be looked into later. John
  1. Load more activity
