- Today
At least yours has been sawn properly. I just got my jacket from the alteration lady this afternoon, and the patch is slightly slanted. Of course, she may not have the eye for it. Never mind that I warned her before the job! Grrr!
- Yesterday
The Commando returns? really?
guzzler replied to p6x's topic in Special place for banter and conversation
Ha ha. Don't hold back now mate! Hilarious. -
Thank you, again, @p6x !
No docc C3 just refers to the bearings internal clearance. The V11 wheel bearings are the classic single row deep groove ball bearing as an example. Phil
Lucky Phil replied to p6x's topic in Special place for banter and conversation
What a total wanker. The bike was rubbish years ago when it was first released and still is. As for British made wank? Well, Wheels and suspension aren't just for starters. Foot pegs and carriers that look like something I made in my workshop. Rubbish sold on "Britishness" that doesn't exist and poor quality, masquerading as rawness and simplicity. Phil -
"deep groove ball bearings" . . . is that the "C3" specification?
I don't back them off docc, too much chance of introducing freeplay. All single/double groove ball bearings will accept a decent amount of axial load and commonly do in practice. It's when it becomes excessive it's an issue such as when the wheel bearing spacer is too short and the amount of torque applied by the axle nut has to be tolerated. Remember even in that case the wheel bearings still last quite a while. In the case of the massive double row ball bearings at the pivot a small amount of preload is preferable to zero or clearance. When I say small I mean "nipped up" to coin an Aussie phrase. Maybe 1 foot pound or so. Think about ball races in a car gearbox main shaft and layshaft for example restraining the lateral force imposed by helical cut gears and 5 or 6 hundred foot pounds of torque generated by the engine. The Koyo bearing catalogue also backs this up for deep groove ball bearings and advises if axial loads are large to increase the shoulder radial depth in the housing. So they accept that significant axial loads will sometimes occur. Phil
audiomick replied to p6x's topic in Special place for banter and conversation
No, not quite. The only way to not have wind noise is to effectively protect the microphone from the wind. It doesn't matter if the mic is built in to the camera, a seperate mic connected to the camera with a cable, or a mic connected to a seperate recorder. You have to isolate it from the wind. That isn't even all that hard. A couple of layers of rubber foam taped over the built-in mic on a camera should do it. If you want to really pay attention to sound quality, the foam or whatever can get expensive, but if you are using something with a built-in mic, don't worry about it. As I said, it isn't all that difficult, actually. All it takes is a bit of common sense, a few minutes of thinking sensibly about the problem, and the awareness that one has to stop wind getting in without damping the pressure waves (sound waves) too much in the process. The wind protectors that look like a fluffy gerbil work quite well, incidently. As far as the camera person goes, towards the end where the bloke is talking after his ride: 1) the camera follows him to the bike where he talks for a minute or two, and the bike's mirror is in front of his face most of the time. 2) he sits at the table and talks for several minutes. During that time the bike in the background is in focus. Ok. But he is not. Not OK. Just to mention a couple of points.... Yes, I'm picky, and nit-picking is easy. But getting it right isn't that difficult either. -
@audiomick The changes will only be required in 2027! they have two years to get it right. I don't know what to think about the reduced engine capacity, but they had to find a way to reduce power. I remember the 800cc fiasco of 2007. This time, it is 850cc, and 20 years later. Possibly the same issues are going to pop up, engines will need to rev higher to compensate for the loss of torque. The 800cc were more prone to high side, but 20 years after, the electronics have evolved too. We will see if they get it right this time. I found this article about the 800cc...https://www.motorcyclenews.com/news/2016/may/mcn-plus---rip-800s-sport/
p6x replied to p6x's topic in Special place for banter and conversation
I am guessing it is his girlfriend. I am going to give some points for not mounting the camera on his head, so the viewer don't have to witness each and every jerking moves, especially while riding in the city. To me, helmet mounted cameras means an early exit and a thumbs down. About wind noise, the only way to not have any, is to have a separate recorder. I have a Zoom H1n which I put inside the tool's compartment of my V11. It works wonders. Only I have no video to speak off, because my DGI Pocket 2 can't handle any wind. As soon as I put it on the chest strap, the gimbal motors are not powerful enough to fight the wind. I am waiting to get a new camera to go back to making some videos of the V11. -
Pressureangle replied to p6x's topic in Special place for banter and conversation
Personally I consider the 'New Commando' a near-miss at best. They really didn't capture any of the proportion or style of the original, and the engine just isn't knobby enough while still appearing dated. Meh. -
Tomchri replied to p6x's topic in Special place for banter and conversation
At least we woud be prepeared to handle the ign lock, looks familiar to me. And the music , hearing the bike, much better. Cool bike, hope they succede. To many has been burned before, paying big down p, thats it, no bike. Cheers Tom. -
Make sure you get everything as clos to 90degree angles and the same angle to get the best shift possible. A VERY old crane mechanic stressed the importance of this to me and I do it as much as possible.
I just had a wee look but not enough time to watch all of it... Think you might be right about the public school twat ha ha . Anyways I don't think they ( Norton ) got it right with the standard Commando,To me the pipes are wrong and the tail lights embedded in the rear cowling look ah crap. Having said this, I think they got it absolutely spot on with the Dominator version, but this was under the previous management. (or lack thereof). That version is one of the best looking bikes I've seen. Cheers Ps I also prefer v twins though. -
I read they are restricting aero to some degree or at least setting parameters based on the max width allowed for the front of the bike.
Well, the bike is pretty. The film is mediocre. The camera person is an amateur, and they don't really have the audio sorted. Wind noise should not ever happen. And the bloke corresponds almost perfectly to the classic stereotype of a public school twat. Ok, that is not really fair, and perhaps says something about my personal predjudices, but still... But the bike really is pretty. Pity I don't like parallel twins. -
The reduction in engine capacity should change the aerodynamic needs, but it won't make them go away. It will make the bikes harder to ride. It likely won't reduce speeds anymore then it did last time they tried smaller engine capacity. As to safety, the smaller engine capacity bikes were arguably less safe as they meant racers had to carry more speed through the corners as the bikes lacked the torque of the larger engine displacement. That tends to lead to more highsides. I am sad that they aren't banning aero, but okay with banning the ride height devices. But the reduction of engine capacity seems misguided, like they don't remember history. The worst thing about all this is we are at a place in time where everyone is so close, and a rules change like this will likely spread the field out as some teams / manufacturers will get it more right then others will.
The first thing that occurs to me is that all the teams will be able to see at all times where all of the bikes are on the track. And be able to calculate speed information out of that. Not entirely useless information, I would say.
The new MotoGP rules starting from 2027 have been announced: Engine Capacity reduced to 850 cc Tank capacity reduced from 22 liters to 20 liters, 11 liters for the short race Fuel will need to be 100% synthetic No ride height or hole shot devices allowed. (this was a really high contention point for Ducati) GPS data of all the riders available to all the teams Only one aerodynamic modification allowed for the rear of the bike. I don't know what the GPS data entails. I suppose it means that you will get the speed only. Not the bike sensor's output. The lesser capacity may resolve into less requirement for aerodynamics the way it is today. I forgot to say, every engine has to be four cylinders, and four cylinders only. Current MotoGP engines are around 300 bhp. I wonder what the reduction in capacity will equate to.
The Norton Commando has been trying to resurrect from its ashes several times now... Let's hope this time it will be real! I really like its looks and how it sounds.
Guzzi-in-Vancouver started following Bikes Bomb in Britain and V11 Shift improvement
Guzzi-in-Vancouver replied to ScuRoo's topic in Special place for banter and conversation
Hi @ScuRoo are there any Aussie commentators like this you could recommend? I follow Matt Barrie (here he is on the Equity Mates show) and would be interested in others of a similar bent. I find it odd that people escape from UK to Oz, and yet the situation almost seems worse there (from the outside). cheers! -
…will do just that, thank you @docc
At one South'n SpineRaid we measured the "standoff" of the threaded part of the pivot pins on six or eight spine frames. I had already taken great pains to set mine to center my tire contact patches to one another using a laser. The conclusion came down to : turn each pivot in equally until they bottom, then back each off very slightly to unload the inner bearing races.
Uh, is it too late to say "set them back to the same depths they were at before you removed the rear swing arm?
