guzziart
Everything posted by guzziart
Hi, I pull the pan on my V11 Lemans when replacing the filter. The original owner put a hose clamp on the filter to keep it from working itself loose so I kept up with the technique. With the hose clamp the filter can't be removed through the filter port in the pan. Plus, I think he may have boogered up the filter cover threads or pan threads...I've not attempted to remove round port cover. I also use a hose clamp on the filter of my LMIV & Eldo. My experience has been that the rubber oil filter base gasket looses tension between filter changes. The hose clamp keeps the filter from rotating loose as the base gasket tension diminishes. As long as the filter doesn't rotate theres a good chance oil pressure won't diminish to critical low levels. My personal experiences with my older MG's has been that the filter is nowhere near as tight when I go to remove it as it was when I installed it. However, since I replace the filter every 2nd oil change maybe the base gaskets have improved over the years and it will be different once I exhaust my current filter inventory. IDK. Art
Sitting here in my recliner.........Maybe a weak ground connection??!! You could try grounding the horns separately to see if the condition changes to where it doesnt effect the tach function. idk. I'm sure someone will be along soon to offer other ideas/fixes. Art
From the album: '03 V11 Lemans
My engine is pinging when loading it, above 4000 rpm...
guzziart replied to p6x's topic in Technical Topics
Kevin T....you're correct. -
I'm running the DAS Mototecs, have them as far aft and up as they'll go without hose replacement & wiring mods. I wouldn't mind trying the Verlicci style set up to see if I can last more than an hour between stops to let blood flow back into my groin area/stave off numbness. Right out of the gate with Verlicci style clips i'd get longer hoses and get with greg bender to fab up some plug n play extension harnesses so I wouldn't have to cobble the oe wiring. Yeah, I;ve given it some thought but so far haven't taken any action. What I don't like about the Mototecs is they require the forks raised up about 10mm higher into the top clamp vs stock set up. So, I'm sitting up slightly higher but have to crane my neck to get my head up that much further to see down the road because of the change in geometry by moving the forks up higher into the top clamp. However, imo, the Mototecs are excellent quality. Oh well. Art
What's the trick to removing the Alternator nut?
guzziart replied to rydfly's topic in Technical Topics
Yeah, these new electric impacts are pretty impressive and getting smaller & less expensive as time goes on. I've got an ancient (bought it in '74, to remove wheel lugnuts on my '67 XR7 to do a brake job in the apartment building parking lot) Crapsman electric that's huge, about the only place I can use it where it's size is not a problem is for wheel lug nuts. Now that I think about it, I can't remember the last time I used the electric, I just fire up the comressor and use the air gun but there could be a battery powered impact in my future...idk. Rydfly, your rotor fin mishap makes me sick, sorry for your loss, hopefully a good used inexpensively priced rotor is readily available. Art -
I wonder if those of you that had to replace the hose AGAIN and AGAIN installed an aftermafket hose or geuine Guzzi item. Yeah, I know MG doesn't make their own hoses but they do specify what the salient characteristics must be, some of those characteristics could be missing from the aftermarket offerings (aka generic, knock off, etc.). Anyway, I've not had to replace mine, it looks good/ok to me, no weather checking and is pliable. However, my breather hose is 20+ years old maybe I should buy one so the next time the tank is off I can replace it. OEM or aftermarket??!! Thanks, Art Geez, I just realized I got way off the oil cooler topic.
My... I'm retired, on a fixed income, don't have deep pockets but when or if my breather hose fails, this is my contingency plan....https://www.mgcycle.com/index.php?main_page=product_info&cPath=71&products_id=1186 .Yeah, it maybe made of material that is not as good as the original or it might be better, who knows, I don't care. Plus it won't be boogered up with a half dozen hose clamps. On the otherhand, if I replaced one of these hoses with an aftermarket piece and it didn't last more that a season or two I'd opt for the genuine oe stuff. FWIW, the breather hose on mine is 20+ years old and shows no sign deterioration (weather checking, etc.) Hope I didn't put the maloik on it by bragging that it's the original. Respectfully submitted, Art PS - I like the $0.02 imoji
My ...... The original owner of my Lemans installed those and when I've had to pull the pipes (twice....for stator and cam chain cover gasket) the task was easier imo than if I had to deal with some other material that was used to seal that connection. Art
170 60 17 rear tireā¦. Pirelli discontinued!?
guzziart replied to arveno's topic in Technical Topics
Oh, I thought I was fortunate to find a 16" front and also a rear that were same make/model in the appropriate size (whatever that is) tire. Not that it matters to me because I don't think I'll be burning through the BT46's ever because the LMIVSE doesn't see alot of action these days but wonder about speed and load ratings of the scooter tires. I'd probably never take the bike over 80/85mph however, the bike is capable of 135+mph in the hands of someone more daring. And then there is the overall weight of the bike which I think is definitely heavier than a scooter. Of ourse there are some big scooters out there in the 600cc neighborhood.....Honda Silverwing 600 comes to mind...weighs as much as the LMIVSE I think. IDK, I'm just rambling, thinking out loud, getting off track and gotta focus on a pair of tires for my '03 Lemans. -
Good thread, especially since my '03 Lemans needs tires, I'll look forward to future posts here before I buy tires. Hey Chuck & Guzzimoto, I put Bridgestone BT46's recently on my '87 LMIVSE w/16' front wheel. I feel the BT46's were a huge improvement over the Dunlop GT 501's that I'd been running. When I got the bike it had the gt501's, I replaced them because when I'd accelerate from a stop into a right or left turn the rear wheel would break loose/lose traction with a little too much throttle and figured they're old, hard, etc. Well, I replaced them with gt501's and the traction loss remained so I wrote it off to the bike being that powerful. So, I burned through gt501's and this last time I went with the BT46's... no more traction issues. Also, after chasing a 38-42mph head shake issue for years...that was gone too. -
Aye Caramba!
FWIW, I tried to install one of those 7" round "Jeep" style sealed LED headlamps in my '03 Lemans. As I recall, the OE lamp is designed to retain the bezel so, the aftermarket Jeep thing I wanted to install was not compatible with the bezel. Leave it to MG to take a design that the rest of the world uses and reverse it. Luckily, my '72 Eldo was manufactured pre-bean counter and I was therefore able to pop the 7 incher into that thing and it works great! Art
I'm not seeing any pics of the "new" Stelvio with bags/panniers. Where am I supposed to put all my stuff??!!
No but I'm right there if you know what I mean...front brake hose almost has no slack with forks fully extended and the start/kill sw wiring had to be rerouted slightly. I don't think I can bring them back any further without replacing hoses and lengthening wiring. Also, it might cause interference issues with the fuel tank. The forks are about a 1/2" higher in the clamps with these risers vs the oem clip ons, i don't notice any difference in handling but the bike sits more "upright" on the side stand because of the risers.
Yamaha XSR900 GP - Wow! want one????
guzziart replied to p6x's topic in Special place for banter and conversation
True but it seems like the Seca has a somewhat comfortable seating position. Maybe they should have shoe-horned a Virago engine into that frame for the V-T look. -
Nice looking bike but the old fogy in me won't let me take a 2nd look. I'm only good for an hour or so on my Lemanses between getting off to let blood flow back into my genitals and think the new Yammy would offer even less saddle time between personal recirculation breaks. Art PS - Watched the vid and wished I was 50 years younger. -
Hey Scud, I think it was after a thread disussion here with you that I went and got the Mojolever & Mark Parnes balancer. I'm still using stick on weights on my cast wheels and wire solder on laced wheels. My '72 Eldo had balancing beads installed by the former owner, the issue I had with those was that every time I checked tire pressure, the shrader valve would stick open and I'd have to give the tire a shot of air to clear the bead debris from the valve seating area otherwise the balancing beads worked ok. When I replaced the tires & tubes on that bike I balanced with external wheel weighting. However, the Ride-On product looks interesting. I do wonder about the difference in dynamics of the wheel assembly by going from a few grams of external weight versus several onces of beads or goo. I suppose it doesn't really matter, folks are using both with no apparent issues. Art
My Nomar. I was never able to manage the technique of using the Nomar tire bar so I went with the Mojolever (it can barely be seen lying on the edge lift table, white tip hanging off the end of the table).
