This stream auto-updates
  1. Past hour
  2. The factory manual gives 0.6-1.2mm clearance or 0.023-0.047" clearance. IDK what the hot setup is. I would think the 0.7mm clearance is the best. You want the tooth to be in the center of the bore when measuring this clearance.
  3. Today
  4. Tinus89
    Neglect
    My experience with putting the S/S out whilst still in gear is that depending on how quick you put it out, it is not an instant-kill but more of a sputter-and-die. PLEASE check your oil level
  5. Been a few years but I've got his email as will.creedon@gmail.com Hope that helps
  6. G'day Mick Yep, back in 2011 the gap on mine was 1.4mm and reduced to 0.7mm! Cheers
  7. Could be, but it could also be a shortcut that illuminates the light shortly. I thought the info of the rerouted wire should need some attention.
  8. If you rerouted the wire of the side stand, you might check ifnit is not stuck and somewhat dismantled under the generator cover. Dont ask how I came up with this idea.
  9. gstallons
    Neglect
  10. Is there current contact information for Will Creedon? I may have one of his chips installed and have some questions.
  11. LowRyter
    Neglect
  12. pete roper
    Neglect
  13. footgoose
    Neglect
  14. Yesterday
  15. swooshdave
    Neglect
  16. audiomick
    Neglect
  17. gstallons
    Neglect
  18. swooshdave
    Neglect
  19. I am at home, with no plans to ride anywhere on 2 wheels for the forseeable future. Lots to do, and I put it back a few weeks for the tour so BACK TO WORK lol
  20. Nicely done - that's a fantastic achievement to knock it all off in one shot...lots of endurance! I bought a 100 raffle tickets for the Norge also (it's the twin of my Norge)...we'll see if I win! Are you headed back to the Norton rally this weekend also?
  21. Oh yeah, and this...may not be too late to enter. hehe
  22. You should look inside the tank of a 87 SE and it looks like it would be better underneath a tree w/o a fuel cap than inside a damp building w/an empty tank.
  23. That'd be good, if you could do that. I'm pretty sure it is in the workshop book somewhere, and will look there, but confirmation from another source is always helpful.
  24. Sailed with a few other TourCats the last few days, since on the same route. Good times in the Starlight Theater restaurant in Terlingua. Big Bend area is definitely on my future target list.
  25. Just got home at noonish. Got my paperwork for my 'official' Iron Butt on the horrid I-10/I-75/FL turnpike ride home, motivated me to get it done. Got every stop except the ALT at the 3 corners marker.
  26. Kevin, Look forward to you joining the Muttoneers! Whether yo join us from a launch from the Moto Grappa (c.450 backroads miles from Pinckney) or meet us in Owensboro (444 ditto), it's childplay for you given your run to and from Tellico Plains! Mutton is an acquired taste, but as I tell folks, "it's acquired me." That day's average speed surprised me, too, as I generally do as you do, i.e., loiter at c.40mph average on backroads. In this case, I smelled the barn and wanted to get home before dark. Moreover, while some of the roads I took were pretty technical and not made for rapid riding -- at least at my age and skill level! ; the stretch of U.S. 50 from Grafton, W.V., to vic. Romney, W.V., comes immediately to mind ... ... there were sections that permitted orange-suit speeds now and then. Must go. Dentist appointment! Bill
  27. Fill it up w/straight gas. You don't want to leave it empty and then take the cap off year later to find RUST.
  28. G'day Mick. Yep,I had my sensor sorted years ago and think from memory you're right the gap should be about 0.7mm. I'll dig the paperwork out and check for sure if need be? Cheers Ps yes it will cause running issues if the gap widens!
  1. Load more activity
