- Past hour
If you rerouted the wire of the side stand, you might check ifnit is not stuck and somewhat dismantled under the generator cover. Dont ask how I came up with this idea.
- Today
BrianG started following Will Creedon
Is there current contact information for Will Creedon? I may have one of his chips installed and have some questions.
- Yesterday
I am at home, with no plans to ride anywhere on 2 wheels for the forseeable future. Lots to do, and I put it back a few weeks for the tour so BACK TO WORK lol -
Nicely done - that's a fantastic achievement to knock it all off in one shot...lots of endurance! I bought a 100 raffle tickets for the Norge also (it's the twin of my Norge)...we'll see if I win! Are you headed back to the Norton rally this weekend also? -
You should look inside the tank of a 87 SE and it looks like it would be better underneath a tree w/o a fuel cap than inside a damp building w/an empty tank.
That'd be good, if you could do that. I'm pretty sure it is in the workshop book somewhere, and will look there, but confirmation from another source is always helpful.
Sailed with a few other TourCats the last few days, since on the same route. Good times in the Starlight Theater restaurant in Terlingua. Big Bend area is definitely on my future target list. -
Just got home at noonish. Got my paperwork for my 'official' Iron Butt on the horrid I-10/I-75/FL turnpike ride home, motivated me to get it done. Got every stop except the ALT at the 3 corners marker. -
Bill Hagan replied to Bill Hagan's topic in Travel & dealers
Kevin, Look forward to you joining the Muttoneers! Whether yo join us from a launch from the Moto Grappa (c.450 backroads miles from Pinckney) or meet us in Owensboro (444 ditto), it's childplay for you given your run to and from Tellico Plains! Mutton is an acquired taste, but as I tell folks, "it's acquired me." That day's average speed surprised me, too, as I generally do as you do, i.e., loiter at c.40mph average on backroads. In this case, I smelled the barn and wanted to get home before dark. Moreover, while some of the roads I took were pretty technical and not made for rapid riding -- at least at my age and skill level! ; the stretch of U.S. 50 from Grafton, W.V., to vic. Romney, W.V., comes immediately to mind ... ... there were sections that permitted orange-suit speeds now and then. Must go. Dentist appointment! Bill -
Fill it up w/straight gas. You don't want to leave it empty and then take the cap off year later to find RUST.
G'day Mick. Yep,I had my sensor sorted years ago and think from memory you're right the gap should be about 0.7mm. I'll dig the paperwork out and check for sure if need be? Cheers Ps yes it will cause running issues if the gap widens!
I definitely spotted the ethanol free pumps. I have yet to try the brisket but I hear it's great. One the guys got the brisket sandwich and they said it was as advertised.
I’ll drain the old fuel out of the machine, as it’s apparently been in there a long time, which can make life more difficult with carbs (or FI). But whats the best option for long term storage… fill it with clear/non ethanol to keep the inside of tank less susceptible to moisture, or leave it dry? i’m in a moist wet environment, so have always defaulted to keeping stored bikes with clean fuel in the tank, but have never planned to store for more than a winter.
It's good to see your back in the saddle again Bill! To tell the truth averaging over 50 miles per hour on back roads is impressive. When planning a trip using all backroads with all my stops I normally figure about 40 mph average. Gives me an idea of saddle time. I got to try some of that mutton one of these days
- Last week
One additional benefit we have here at the local Bucee's is 91 Octane Ethanol free gas...coupled that with a fresh brisket taco and a coffee and you're good to go!
If you haven't been it's a bucket list item. The pictures do it no justice. From Tennessee you have no excuse not to go.
