This stream auto-updates
  1. Past hour
  2. Been a few years but I've got his email as will.creedon@gmail.com Hope that helps
  3. Today
  4. G'day Mick Yep, back in 2011 the gap on mine was 1.4mm and reduced to 0.7mm! Cheers
  5. Could be, but it could also be a shortcut that illuminates the light shortly. I thought the info of the rerouted wire should need some attention.
  6. If you rerouted the wire of the side stand, you might check ifnit is not stuck and somewhat dismantled under the generator cover. Dont ask how I came up with this idea.
  7. gstallons
    Neglect
  8. Is there current contact information for Will Creedon? I may have one of his chips installed and have some questions.
  9. LowRyter
    Neglect
  10. pete roper
    Neglect
  11. footgoose
    Neglect
  12. Yesterday
  13. swooshdave
    Neglect
  14. audiomick
    Neglect
  15. gstallons
    Neglect
  16. swooshdave
    Neglect
  17. I am at home, with no plans to ride anywhere on 2 wheels for the forseeable future. Lots to do, and I put it back a few weeks for the tour so BACK TO WORK lol
  18. Nicely done - that's a fantastic achievement to knock it all off in one shot...lots of endurance! I bought a 100 raffle tickets for the Norge also (it's the twin of my Norge)...we'll see if I win! Are you headed back to the Norton rally this weekend also?
  19. Oh yeah, and this...may not be too late to enter. hehe
  20. You should look inside the tank of a 87 SE and it looks like it would be better underneath a tree w/o a fuel cap than inside a damp building w/an empty tank.
  21. That'd be good, if you could do that. I'm pretty sure it is in the workshop book somewhere, and will look there, but confirmation from another source is always helpful.
  22. Sailed with a few other TourCats the last few days, since on the same route. Good times in the Starlight Theater restaurant in Terlingua. Big Bend area is definitely on my future target list.
  23. Just got home at noonish. Got my paperwork for my 'official' Iron Butt on the horrid I-10/I-75/FL turnpike ride home, motivated me to get it done. Got every stop except the ALT at the 3 corners marker.
  24. Kevin, Look forward to you joining the Muttoneers! Whether yo join us from a launch from the Moto Grappa (c.450 backroads miles from Pinckney) or meet us in Owensboro (444 ditto), it's childplay for you given your run to and from Tellico Plains! Mutton is an acquired taste, but as I tell folks, "it's acquired me." That day's average speed surprised me, too, as I generally do as you do, i.e., loiter at c.40mph average on backroads. In this case, I smelled the barn and wanted to get home before dark. Moreover, while some of the roads I took were pretty technical and not made for rapid riding -- at least at my age and skill level! ; the stretch of U.S. 50 from Grafton, W.V., to vic. Romney, W.V., comes immediately to mind ... ... there were sections that permitted orange-suit speeds now and then. Must go. Dentist appointment! Bill
  25. Fill it up w/straight gas. You don't want to leave it empty and then take the cap off year later to find RUST.
  26. G'day Mick. Yep,I had my sensor sorted years ago and think from memory you're right the gap should be about 0.7mm. I'll dig the paperwork out and check for sure if need be? Cheers Ps yes it will cause running issues if the gap widens!
  27. I definitely spotted the ethanol free pumps. I have yet to try the brisket but I hear it's great. One the guys got the brisket sandwich and they said it was as advertised.
  28. I’ll drain the old fuel out of the machine, as it’s apparently been in there a long time, which can make life more difficult with carbs (or FI). But whats the best option for long term storage… fill it with clear/non ethanol to keep the inside of tank less susceptible to moisture, or leave it dry? i’m in a moist wet environment, so have always defaulted to keeping stored bikes with clean fuel in the tank, but have never planned to store for more than a winter.
  1. Load more activity
