This stream auto-updates
  1. Past hour
  2. audiomick
    Neglect
    That depends on the fault. Assuming it did have something to do with that switch, the bike ran again later, so it can be considered an intermittant fault. I gather the bike was rolling when it died. So if the switch was cutting in and out, the momentum could easily have "push started" the bike a couple of times before it finally died. All crystal ball stuff from here, but it seems plausible to me. Since you worked on and around the switch recently, and now the motor is cutting out, I would definitely have another look at it and make sure it went back together properly.
  3. Today
  4. gstallons
    Neglect
    You have two issues to address; As Roper,Tinus , I and others will verify , this light is not "for entertainment purposes only". Replace the oil press. switch and go looking. Remove the manhole cover and take off the filter and inspect the seal on the filter. Install a new filter / oil. Get this filter SNUG. when you install the manhole cover push against the pan and rotate it like you are removing it . When it clicks , stop turning and tighten it. This way you will not cross thread it. Install a new o-ring on the cover too. The majority of engine failures come down to loose oil filters. these are inside the oil pan and impossible to know if they are tight/loose until something bad happens. we don't want you to have a 500lb piece of junk in your yard. It is not easy coming up w/another engine.
  5. The factory manual gives 0.6-1.2mm clearance or 0.023-0.047" clearance. IDK what the hot setup is. I would think the 0.7mm clearance is the best. You want the tooth to be in the center of the bore when measuring this clearance.
  6. Tinus89
    Neglect
    My experience with putting the S/S out whilst still in gear is that depending on how quick you put it out, it is not an instant-kill but more of a sputter-and-die. PLEASE check your oil level
  7. Been a few years but I've got his email as will.creedon@gmail.com Hope that helps
  8. G'day Mick Yep, back in 2011 the gap on mine was 1.4mm and reduced to 0.7mm! Cheers
  9. Could be, but it could also be a shortcut that illuminates the light shortly. I thought the info of the rerouted wire should need some attention.
  10. If you rerouted the wire of the side stand, you might check ifnit is not stuck and somewhat dismantled under the generator cover. Dont ask how I came up with this idea.
  11. gstallons
    Neglect
  12. Is there current contact information for Will Creedon? I may have one of his chips installed and have some questions.
  13. LowRyter
    Neglect
  14. pete roper
    Neglect
  15. footgoose
    Neglect
  16. Yesterday
  17. swooshdave
    Neglect
  18. audiomick
    Neglect
  19. gstallons
    Neglect
  20. swooshdave
    Neglect
  21. I am at home, with no plans to ride anywhere on 2 wheels for the forseeable future. Lots to do, and I put it back a few weeks for the tour so BACK TO WORK lol
  22. Nicely done - that's a fantastic achievement to knock it all off in one shot...lots of endurance! I bought a 100 raffle tickets for the Norge also (it's the twin of my Norge)...we'll see if I win! Are you headed back to the Norton rally this weekend also?
  23. Oh yeah, and this...may not be too late to enter. hehe
  24. You should look inside the tank of a 87 SE and it looks like it would be better underneath a tree w/o a fuel cap than inside a damp building w/an empty tank.
  25. That'd be good, if you could do that. I'm pretty sure it is in the workshop book somewhere, and will look there, but confirmation from another source is always helpful.
  26. Sailed with a few other TourCats the last few days, since on the same route. Good times in the Starlight Theater restaurant in Terlingua. Big Bend area is definitely on my future target list.
  27. Just got home at noonish. Got my paperwork for my 'official' Iron Butt on the horrid I-10/I-75/FL turnpike ride home, motivated me to get it done. Got every stop except the ALT at the 3 corners marker.
  1. Load more activity
